Cycles OpenImageDenoise makes Blender crash on MacOS
Closed, ResolvedPublicBUG
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.11.22
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-08-17 19:11, hash: rBc65c66320fc8
Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-08-18 19:29, hash: rBd5b5b228e4d0
Worked: version 2.90.0 Alpha, branch: master, commit date: 2020-06-30 20:02, hash: a3e6b7c2ce06
(I did not test versions in between.)
Blender crashes every time I use OpenImageDenoise
Open Blender
Load Factory Settings
Switch to Cycles Render Engine
Enable OpenImageDenoise in Viewport or Final Render
Switch to rendered preview or press F12 -> Blender crashes
The strange thing is that when I start Blender via the Terminal command
/Applications/Blender.app/Contents/MacOS/Blender ;
it just works fine.
Attached: MacOS crash report
It looks like OIDN might have just fixed this upstream.
https://github.com/OpenImageDenoise/oidn/blob/master/CHANGELOG.md
Fixed incorrect detection of AVX-512 on macOS (sometimes causing a crash)
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Mon, Sep 14, 9:22 PM
Here's a test build with a potential fix:
https://download.blender.org/ftp/brecht/builds/blender-macos-simd-fix0.dmg
Can you test if it helps? I don't have the right hardware to test this.
It works! Thank you Brecht!
I've tried that blender-macos-simd-fix0 test build in my Mac Pro 2010 with Radeon RX 560 and it keeps on crashing upon switching to Cycles. I attach a crash log.
MacPro5.1
6-Core Intel Xeon 3.46 GHz
32 GB RAM
Radeon RX 560 4096 MB
