Shrink mask doesn't work if all polys are masked on non-watertight geometry #80032
Reference: blender/blender#80032
Operating system: Darwin-16.7.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 980 OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.18.5 378.05.05.25f19
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-08 15:55, hash:
9f7d84b656
Shrink mask doesn't work if all polys are masked on a geometry with borders (non-watertight)
Make a grid. Go to sculpt mode. mask everything, shrink. Nothing happens.
I was trying to find a way to pin the borders of my geometry. I though I could mask everything, shrink, then inverse the mask.
Being able to pin the borders is a must for sculpting. It should be part of Blender.
Added subscriber: @Funnybob
Added subscribers: @PabloDobarro, @iss
It doesn't look like geometry has to be not-watertight
If I understand code well, it changes value of mask to be same as neighbor valueit neighbors is lower. That means that shrink can't result in mask with lower value than existing lowest mask value.
Your described workflow seems useful but that would be feature request. @PabloDobarro what do you think about this?
I wrote non-watertight because if you grow the mask all the way on a sphere, then it won't have a way to know from where to shrink, unless Blender keeps the history in memory. Anyway, as a user, I don't really care how the code works. If the function is called shrink mask and in that situation it doesn't do it, then it's a bug. :-) Cheers
I tested it again and I realized that as soon as the mask reaches the edge of the geometry, it won't shrink again, so it's not only when everything is masked.
While we're on the mask subject, I found that it's impossible to select the centre of a geometry using the lasso mask tool because as soon you exit the menu, the lasso is active and you can't reach the part you want without affecting the rest. It should be like the box select. It's active only once you've click, which is the behaviour of the lasso tool for vertices.
In Maya, there's a cool feature for sculpting that I dearly miss. If you have vertices selected before going into the sculpt tool, then only the selected vertices will be affected by the sculpt tool, so no need to deal with masks (masks are also available). There are many ways to select vertices in Blender and that would be super useful. It's much faster than having to create masks. This is the point of view of a hard surface modeler. It seem like the sculpt tool was design with organic modelling in mind, X mirror being on by default (which is very annoying for hard surfaces). X mirror should not be turned on by default or at least it should be in the prefs somewhere to that the user can decide. OK, I'm done.
There is boundary automasking which already pins mesh borders. I can make a separate tool for generating a mask from the borders, but I don't think shrink mask should do that, otherwise you won't be able to do this:
2020-08-25 15-34-02.mp4
Really? Cool. How?
Help me Obiwan Kenobi. You're my only hope.
Good point.
