[2.83.5/2.90 beta] Artifacts and invisible faces when assigning multiple materials #80037
Reference: blender/blender#80037
Graphics card: GeForce 9300 GE/PCIe/SSE2 NVIDIA Corporation 3.3.0
Broken: version: 2.83.5, branch: master, commit date: 2020-08-19 06:07, hash:
c2b144df39
Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-08-19 10:14, hash:
83c78529b9
Worked: 2.82
Faces become invisible and produce artifacts in the viewport, if assigned to materials from any slot other than the first slot.
You can still select invisible faces in edit mode
This is the original mesh with only one material applied
Open Blender, select the default cube and make sure it has more than one material.
In Edit mode, assign any face to the material from the second or the third slot.
Here I attached two .blend files, one with the window seen above and one with the default cube:
Window.blend
Cube.blend
Added subscriber: @(Deleted)
Artifacts and invisible faces when assigning multiple materialsto [2.83.5/2.90 beta] Artifacts and invisible faces when assigning multiple materialsAdded subscriber: @rjg
The NVIDIA GeForce 9300 GE is from the GeForce 9 (9xxx) series and was release in June 2008. It has 256 MB of memory.
This graphics card does not fulfill the minimum requirements for running Blender 2.83/2.9x.
Unless you or others can reproduce the issue on supported hardware we will have to close this ticket.
Added subscriber: @anmorgul
same problem
xubuntu18
CPU (not GPU)
open old project with new version blender:
2.8
2.9
@anmorgul Please read [this guide ]], it may help you write a bug report that allows us to fix your problem. In particular check that your GPU fulfills the [ https:*www.blender.org/download/requirements/ | minimum requirements for running Blender and that the graphics driver is up to date.
If your hardware is supported, then please create a new report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
