Clay brushes "Front Faces Only" still affecting backfaces
Confirmed, NormalPublic
Graphics card: GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.20
Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-08-25 16:00, hash: rB21cb6f09ffa8
Worked: 2.83 LTS (Not working perfectly, but better)
Clay sculpt brushes (Clay Strips, Clay) - Only when adding clay (not carving in), affects geometry of the other side(extruded hole for example) (with high enough brush radius). "Front faces only" option does not help.
2.83 Seem to be working better(not perfect), issue seems to be worse in 2.9+
(Would be great with an option to tweak Depth value on brushes manually)
Bigger brush radius seems to be the issue, however this is a problem that only affects Clay brushes.
  1. Open file
  2. Sculpt
One side is pre-damaged for demonstration.
Thanks for the report,
In order to make the bug confirmation process a little easier, can you provide the file showing the problem?
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Wed, Sep 2, 12:07 AM
Richard Antalik (ISS) updated the task description. (Show Details)
