Large scale volumetric object with large step size causes rendering artifacts on CPUs in Cycles. #80267
Closed
opened 2020-08-31 05:58:27 +02:00 by Alaska · 11 comments
Member
System Information 1:
CPU: Ryzen 9 3900X
GPU: GeForce RTX 2060 SUPER 451.67
System Information 2:
CPU: Intel i5 8400
Blender Version:
Broken: version: 2.80, 2.81, 2.82, 2.83, 2.90 21cb6f09ff (2020-08-25 16:00), 2.91.0 396d39c6b9 (2020-08-25 19:28)
Worked: NA
Short description of error:
When a volumetric object is sufficiently large, the volumetric step size is large, and the density high enough (Desnity of around 1 or higher) rendering artifacts can occur when rendering with the CPU. I have been unable to replicate this issue using CUDA and OptiX (possible explanation later).
Here's a video demonstrating the artifacts and what happens as the size of an object decreases (left) and as the step size of the volume decreases (right).
Figure 1.mp4
The issue seems to stem from the use of "Equiangular" sampling on the volumetric objects. Changing the sampling method to "Distance" seems to resolve the issue. I assume "Multiple Importance" sampling (the default) is using Equiangular sampling in this situation. This does not appear to affect GPU rendering as the GPU can not use "Multiple importance" or "Equiangular" sampling (at least from my understanding).
Here's an example image showing "Equiangular/Multiple importance" and "Distance" sampling side by side.
This issue also seems to be harder to naturally reproduce in Blender 2.82 and earlier simply down to the fact the default step size in those versions of Blender tended to be smaller than those used in Blender 2.83 and later.
Exact steps for others to reproduce the error:
  1. Change the render engine to Cycles.
  2. Give an object a volumetric shader. I gave mine a spherical gradient texture to use as it's density with a colour ramp to add contrast.
  3. Add a sun lamp so it's easier to see the volume.
  4. Scale up the volume until rendering artifacts occur (I used a scale of ~500 with the default cube).
  5. You should now see artifacts in the volume if you render the scene.
  6. If you now play around with decreasing the volumetric step size, rendering the scene with a GPU, or changing the sampling method to "Distance", you should see that the artifacts disappear.
Here's an example scene with an animation:
#80267 - Volumetric Artifacts.blend
**System Information 1:** Operating system: Windows-10-10.0.19041-SP0 64 Bits CPU: Ryzen 9 3900X GPU: GeForce RTX 2060 SUPER 451.67 **System Information 2:** Operating system: Windows-10-10.0.18362-SP0 64 Bits CPU: Intel i5 8400 **Blender Version:** Broken: version: 2.80, 2.81, 2.82, 2.83, 2.90 `21cb6f09ff` (2020-08-25 16:00), 2.91.0 `396d39c6b9` (2020-08-25 19:28) Worked: NA **Short description of error:** When a volumetric object is sufficiently large, the volumetric step size is large, and the density high enough (*Desnity of around 1 or higher*) rendering artifacts can occur when rendering with the CPU. I have been unable to replicate this issue using CUDA and OptiX (*possible explanation later*). Here's a video demonstrating the artifacts and what happens as the size of an object decreases (left) and as the step size of the volume decreases (right). [Figure 1.mp4](https://archive.blender.org/developer/F8824467/Figure_1.mp4) The issue seems to stem from the use of "Equiangular" sampling on the volumetric objects. Changing the sampling method to "Distance" seems to resolve the issue. I assume "Multiple Importance" sampling (the default) is using Equiangular sampling in this situation. This does not appear to affect GPU rendering as the GPU can not use "Multiple importance" or "Equiangular" sampling (at least from my understanding). ![Figure 2.png](https://archive.blender.org/developer/F8824469/Figure_2.png) Here's an example image showing "Equiangular/Multiple importance" and "Distance" sampling side by side. ![Figure 3.png](https://archive.blender.org/developer/F8824471/Figure_3.png) This issue also seems to be harder to **naturally** reproduce in Blender 2.82 and earlier simply down to the fact the default step size in those versions of Blender tended to be smaller than those used in Blender 2.83 and later. **Exact steps for others to reproduce the error:** 1. Change the render engine to Cycles. 2. Give an object a volumetric shader. I gave mine a spherical gradient texture to use as it's density with a colour ramp to add contrast. 3. Add a sun lamp so it's easier to see the volume. 4. Scale up the volume until rendering artifacts occur (I used a scale of ~500 with the default cube). 5. You should now see artifacts in the volume if you render the scene. 6. If you now play around with decreasing the volumetric step size, rendering the scene with a GPU, or changing the sampling method to "Distance", you should see that the artifacts disappear. Here's an example scene with an animation: [#80267 - Volumetric Artifacts.blend](https://archive.blender.org/developer/F8824475/T80267_-_Volumetric_Artifacts.blend)
Author
Member
Added subscriber: @Alaska
Contributor
Added subscriber: @Raimund58
Added subscriber: @mano-wii
I can confirm the problem.
In fact, it is only seen with the CPU and is related to the "Multiple Importance" settings in the volume material.
I can confirm the problem. In fact, it is only seen with the CPU and is related to the "Multiple Importance" settings in the volume material.
Added subscriber: @ktdfly
Looks similar to #56925 (Cycles produces banded render artifacts in dense or sharp volume renders.)
Author
Member
The issues appear to be different and the issue reported in this bug report was not fixed with the fix for #56925. However, the new Cycles-X branch of Blender seems to fix this issue and as such this report will probably be closed when Cycles-X is merged into master.
> In #80267#1218574, @ktdfly wrote: > Looks similar to #56925 (Cycles produces banded render artifacts in dense or sharp volume renders.) The issues appear to be different and the issue reported in this bug report was not fixed with the fix for #56925. However, the new Cycles-X branch of Blender seems to fix this issue and as such this report will probably be closed when Cycles-X is merged into master.
This issue was referenced by blender/cycles@5db8d93df3
This issue was referenced by blender/cycles@5db8d93df3800ed9e90651ca305611c0612e606d
This issue was referenced by 0803119725
This issue was referenced by 08031197250aeecbaca3803254e6f25b8c7b7b37
Brecht Van Lommel self-assigned this 2021-09-21 15:00:59 +02:00
6 Participants
Reference: blender/blender#80267
