'context.scene' not updating correctly from prop update function #80431
5 Participants
Reference: blender/blender#80431
Operating system:
Graphics card:
Broken: 2.8x (tested 2.80, 2.83), 2.90
Worked: Never
When the active scene is changed by a property updater from the 'Scene' panel context, the
context.scene
property of the operator's context is not updated correctly. Similar to #75352, though cannot be fixed with the resolution described there.Exact steps for others to reproduce the error
test_prop
integer to something different. This will trigger thenew_scn
update function, which creates a new scene and sets it to the active scene. If it worked correctly, the names printed to the console should match.Added subscriber: @bblanimation
Added subscribers: @ideasman42, @iss
I can confirm, but I am not sure if this is bug. @ideasman42 Can you check this?
Added subscriber: @lichtwerk
Please do so :)
Checking on this, it would require a refresh/redraw of the UI immediately after setting the active scene, so the properties-editor updates the Scene path.
Closing this since depending on the context isn't likely to work well, the user may - for example pin the scene in the properties editor, so even if it was made to update in some cases, it wouldn't work reliably.
Note that, setting the scene from a properties update callback seems quite error prone too.
Added subscriber: @pauanyu_blender
