Deleting bone constraints when the armature layer isn't active crashes Blender #80464
Reference: blender/blender#80464
Operating system: Win 10
Graphics card: RTX2070
Broken: 2.90, 2.91 alpha
Worked: 2.83.5
Caused by 608d9b5aa1: UI: Add shortcuts for constraint panels
The attached file has 2 bones in 1 armature. Bone.001 is constrained to Bone, and the two bones are in separate armature layers. With both layers active, deleting the constraint in Bone.001 works normally. But if layer 16 isn't active, doing the same thing will crash Blender.
crashtest_2_90.blend
Added subscriber: @alphis
Added subscriber: @lichtwerk
Can confirm.
Caused by
608d9b5aa1
Prior to
608d9b5aa1
, the constraint was gotten using context [CTX_data_pointer_get_type(C, "constraint", &RNA_Constraint) -- which is valid for bones on hidden layers].After
608d9b5aa1
, the constraint is found (or isnt) usingedit_constraint_property_get
[this is not valid for bones on hidden layers because internallyBKE_pose_channel_active
checks if the bone is on an active layer].Some observations:
doesnt work for bones on inactive layers [delete, moveup, movedown, move to index (drag n drop nowadays)]edit_constraint_property_get
for constraint data doesnt work for bones on inactive layers [stretchto_reset, limitdistance_reset, childof_set_inverse, ...]This is because the poll function is using context to get the constraint, the operators themselves use edit_constraint_property_get which leads to inconsistent/unexpected results.
Possible solutions:
608d9b5aa1
) -- allows for deleting constraints on bones in inactive layersedit_constraint_poll_generic
be as strict as the operators -- dont use context to get the constraint, but something like edit_constraint_property_getWhatever we decide upon: this might be a candidate for 2.90.1? Will check on all solutions, might go for the quick fix - [x] first, then try [4]?
Note: Adding constraints also doesnt work for bones on inactive layers [that was the case in 2.79 as well -- it is also using
]Note:
edit_constraint_invoke_properties
also uses said contextAdded subscriber: @dr.sybren
Good find @lichtwerk. I think it's important to have the poll function actually in sync with the rest of the operator; without that, it's rather useless. And first doing - [x] and then trying - [x] sounds good to me.
This issue was referenced by
8b953fa83d
9dcae4eb17
7447233f76
6dc7266cf1
