fbx export bug #80584
5 Participants
Reference: blender/blender#80584
Operating system: Windows-10-10.0.14393-SP0 64 Bits
Graphics card: AMD Radeon(TM) RX Vega 11 Graphics ATI Technologies Inc. 4.5.13571 Core Profile Context 19.30.28 26.20.13028.13
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: `0330d1af29#
Worked: #newest version of Blender that worked as expected#
[Based on the default startup or an attached .blend file #as simple as possible#]
hi
I try export fbx file but blender get error
I make file in blender 2.83 and edit in blender 2.90
Added subscriber: @meysamFk97
Added subscriber: @gobb_blend
I'm having the same issue when exporting certain meshes as FBX. I'm on Blender 2.9. Windows10. Though the issue is also present on 2.83.
I made a minimal test file. A single triangle can cause this error.
To reproduce, simply try to export this as an FBX to any location.
cant_export_fbx.blend
One odd thing that I noticed as an end user is that some of the vertices in the mesh don't appear in the UV Editor. Simply unwrapping the mesh again solves the problem, and export then works as expected. But obviously, this shouldn't even happen in the first place.
Added subscriber: @rjg
@gobb_blend Could you describe how you've created the model that fails to export?
@rjg This issue happened to a coworker of mine, but I'll try to rephrase what they said.
The only noteworthy thing about the creation of this mesh is that they copy-pasted (Ctrl-C, Ctrl-V) the object from one Blender instance to another (both 2.83) and then continued working on the copy. They extruded part of the mesh, and a few of those resulting vertices ended up being broken. The extrusion created new vertices in the mesh, but not in the UV layer -- at least some connections are missing from what I can tell.
Here's a more complete version of the original model with the extruded part clearly emphasized.
What makes this bug even worse is the fact that this broken state is propagated to all vertices created from the broken ones, for example by extruding or loop-cutting them. None of the new vertices will show up in the UV editor.
Added subscriber: @iss
@gobb_blend Do you have original file from which this object has been copied? We will need to reproduce this data corruption to fix the problem
building1.blend
@iss Here's the original file. Allegedly, pasting this into a new file and then extruding parts of the door frame was enough to cause the issue at hand. Though, even after a handful of tries I haven't been able to reproduce it, so it might be something else entirely.
Added subscriber: @lichtwerk
Thx for the additional information.
This has been reported before, see #79775 (Something in Blender can generate invalid (Nan) values in UVMaps) and other merged reports for more information.
Will merge these reports (and also put new information from this one there).
Closed as duplicate of #79775
