Python operator material_slot_assign() doesn't work in 2.91 alpha #80597
Closed
opened 2020-09-08 15:48:36 +02:00 by Aleksi Tuomela · 9 comments
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-04 21:32, hash: cf0ba59e31
Worked: 2.90
When using the "assign" button from the UI in edit mode ("assign active material to slot" in the material properties) it works as expected, but when using bpy.ops.object.material_slot_assign() from the python console, it only outputs {'CANCELLED'} instead of {'FINISHED'} like in 2.90.
User Iceythe on Blenderartists thought it might have to do with Campbell's work on material assigning here: https://developer.blender.org/diffusion/B/browse/master/source/blender/editors/render/render_shading.c%24273
"Can confirm it worked on 2.90 alpha and does not work on 2.91. Campbell worked on the material assign operator just a week ago and most notably the line 273 is a call to a function that tries to fetch objects based on “context.area” being the properties editor.
You can override with area set to the properties editor, but I’d call that a regression in any case."//
  • startup blend
  • make a second material slot for the default cube (with a new material also), leave the new slot selected
  • go to edit mode, select 1 face
  • switch to scripting workspace
  • type bpy.ops.object.material_slot_assign() to the console, hit enter
  • the face doesn't get assigned to the 2nd material slot
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92 **Blender Version** Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-04 21:32, hash: `cf0ba59e31` Worked: 2.90 **Short description of error** When using the "assign" button from the UI in edit mode ("assign active material to slot" in the material properties) it works as expected, but when using bpy.ops.object.material_slot_assign() from the python console, it only outputs {'CANCELLED'} instead of {'FINISHED'} like in 2.90. User Iceythe on Blenderartists thought it might have to do with Campbell's work on material assigning here: https://developer.blender.org/diffusion/B/browse/master/source/blender/editors/render/render_shading.c%24273 > "Can confirm it worked on 2.90 alpha and does not work on 2.91. Campbell worked on the material assign operator just a week ago and most notably the line 273 is a call to a function that tries to fetch objects based on “context.area” being the properties editor. > You can override with area set to the properties editor, but I’d call that a regression in any case."// **Exact steps for others to reproduce the error** - startup blend - make a second material slot for the default cube (with a new material also), leave the new slot selected - go to edit mode, select 1 face - switch to scripting workspace - type bpy.ops.object.material_slot_assign() to the console, hit enter - the face doesn't get assigned to the 2nd material slot
Author
Added subscriber: @AleksiTuomela
Added subscriber: @mano-wii
Germano Cavalcante self-assigned this 2020-09-11 16:11:54 +02:00
bpy.ops.object.material_slot_assign() is one of the operators that requires to be called in a specific context.
When called on the console, it does not decide which scene, view3d, objects to use in the operation.
It is possible to get around this, but the bug tracker is not the right place to talk about it.
For help using Blender, please try one of the community websites: https://www.blender.org/community/
`bpy.ops.object.material_slot_assign()` is one of the operators that requires to be called in a specific context. When called on the console, it does not decide which scene, view3d, objects to use in the operation. It is possible to get around this, but the bug tracker is not the right place to talk about it. For help using Blender, please try one of the community websites: https://www.blender.org/community/
Changed status from 'Archived' to: 'Confirmed'
Germano Cavalcante removed their assignment 2020-09-11 16:18:31 +02:00
Added subscriber: @ideasman42
In the second analysis, this used to work.
Perhaps now it is a limitation, but since it is a regression I think it is worth taking a look.
Regression introduced in 1a650fdcb2
In the second analysis, this used to work. Perhaps now it is a limitation, but since it is a regression I think it is worth taking a look. Regression introduced in 1a650fdcb2
Campbell Barton self-assigned this 2020-09-15 02:56:49 +02:00
This issue was referenced by 61cd0d5bd5
This issue was referenced by 61cd0d5bd58115741e0089adf56ac42e5c79d96d
Reference: blender/blender#80597
