Bezier incorrect behavior during transformations
Closed, ResolvedPublicBUG
Operating system: Ubuntu 18.04
Graphics card: GeForce GT 650M
Broken: 2.9+
Worked:
Start position:
Expected view (key: G Z -1):
at the exit: (Shift+S , Selection to Cursor):
with Handle scale
File fo Experiment{F8871907}
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Sep 14 2020, 10:51 AM
Cannot reproduce here, this is what I get in the end:
Also what is not clear to me is the following:
Selection to Cursor
  • your screenshots show the cursor in the origin, in your file, the cursor is at 0 0 1, which one is right?
  • is this step relevant to reproduce the issue?
with Handle scale
  • is this step relevant to reproduce the issue? (what should I do? just S?)
Sorry if dont get this right, maybe you can try to explain again (maybe screencast could help as well)
All History:
Ctrl-N
1
X
Shift+A 21
RY90
RZ90
TAB
Select TOP Point Segment With Handles
SX0
Object Data Properties - Bevel [0.14]
Select only TOP Point without handles
Shift+S8
Campbell Barton (campbellbarton) changed the task status from Needs Information from User to Confirmed.EditedSep 22 2020, 7:16 AM
Campbell Barton (campbellbarton) changed the subtype of this task from "Report" to "Bug".
When following these steps I end up with a flat shaped curve, which changed in 2.81, it works in 2.80, needs to be further bisected.
