Compositor backdrop handles alpha differently from image editor #80748
7 Participants
Reference: blender/blender#80748
Operating system: Linux-5.8.6-1-MANJARO-x86_64-with-glibc2.32 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.8.6-1-MANJARO, LLVM 10.0.1) X.Org 4.5 (Core Profile) Mesa 20.1.7
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-13 09:15, hash:
f5ccf8727f
Worked: 2.90
Keying node alpha channel is not taken into account 100% when rendering.
On attached file:
2.90: background keyed out (not perfect because I left everything else on defaults)
2.91 alpha: background looks desaturated semi-transparent
or
Keying node bug.blend
Added subscriber: @georgK
Added subscribers: @Jeroen-Bakker, @mano-wii
It is indeed a regression.
@Jeroen-Bakker, I wonder if it has anything to do with the recent changes in the image editor.
Backdrop rendering looks normal in version: 2.91.0 Alpha, branch: master, commit date: 2020-09-17 20:18, hash:
9ee588cd4a
, but F12 rendering still has artifacts.Added subscribers: @brecht, @Sergey
Keying node violates pre-multiplication of the compositing buffer: it sets alpha without multiplying color channels. The original motivation behind this was to be able to chain multiple keying nodes. But now it seems that this decision causes more problems than solutions, so probably need to ensure pre-multiplication of result at where it is expected to be.
However, "fixing" this specific node does not fix the issue in general: there are many more ways to "ruin" pre-multiplication in compositor, and having difference between compositor backdrop and image editor is rather confusing.
@brecht, proposal: add "Convert Premul" checkbox enabled by default, but not do-versioned for existing files, so that compatibility is not ruined. That would at least cover common usecases of this specific node. The backdrop drawing is still needs to be corrected, but that's a different story where I can not help.
I'm fine with a Convert Premul option on the keying node.
Added D9211 which sanitizes the keying node alpha behaviour.
@Jeroen-Bakker, @brecht, I would like you to make the decision about alpha rendering difference between image editor and compositor backdrop. To me it seems confusing at a least :(
I guess it's just a bug to be fixed by @Jeroen-Bakker, to ensure the compositor backdrop draws the same way as the image editor?
Not sure there is any decision to take from my side.
The keying node now delivers properly premultiplied color. There is also Cryptomatte node which needs to be made to output proper color. There is #82154 about it.
I still believe root of this issue goes to the fact that image editor uses different drawing of alpha than the rest of related editor (compositor backdrop, movie clip editor).
@Jeroen-Bakker, is it something you think can be addressed for 2.92? Do you want to adjust projects tags?
Keying node bugto Compositor backdrop handles alpha differently from image editorYes, I am planning to work on it for 2.92. I will merge my todo into this task.
Added subscriber: @fclem
Technical challenge
The backdrop is rendered between parent node tree and the current active node tree.
#80748.blend
Current layering in the draw code is:
Everything is currently done in display space to an offscreen image.
Solutions
Additional benefit of the GPUViewport solution is that stereoscoptic compositing will also give the same result as in the 3d viewport or image editor as they shade the same color pipeline.
@fclem do you have any suggestion?
The ideal solution would be to do something like the 3D view: At 6, draw the backdrop only using a holdout for it's alpha channel. This would let the render pass through the overlays and display correctly.
So your idea is good and yes the GPUViepwort would handle stereo correctly.
This issue was referenced by
278011e44d
