Rigify - basic.raw_copy bones with ORG prefix are not generated correctly #80764
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#80764
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.83.6, 2.9 & 2.91
Worked: (not sure)
Addon Information
Name: Rigify (0, 6, 1)
Author: Nathan Vegdahl, Lucio Rossi, Ivan Cappiello, Alexander Gavrilov
basic.raw_copy bones with ORG prefix are not generated correctly (or at least not as I expect)
Expected behavior:
The bone is moved to layer 31 and it retails the name "ORG-bone" in the generated rig.
Actual behavior in the current version of Rigify:
The bone remains in the same layer as in the meta rig. It also loses the "ORG-" prefix. So "ORG-bone" is renamed to "bone".
I started trying to figure out raw_copy recently so it could be that I misunderstood something.
But this is inconsistent with the raw_copy's that have MCH or DEF prefix.
Bones with MCH- prefix are moved to layer 30 and retain the prefix.
Bones with DEF- prefix are moved to layer 29 and retain the prefix.
Only ORG bones don't follow this pattern.
Added subscriber: @TodorNikolov
Added subscribers: @angavrilov, @icappiello, @Mets
@angavrilov is there a specific design reason for that? can't exactly tell if is a bug or an intended design.
This is a technical limitation of implementing raw_copy using only the 'public' rig API: it works by removing the ORG prefix that is added as usual by generate, which doesn't add the prefix if the bone already has it to avoid creating 'ORG-ORG-whatever'. This can only be fixed by adding a special case check for raw_copy directly in generate code, or maybe saving a table of the 'true original names' for the bones so raw_copy can use it.
I didn't give this case much thought because I wanted to showcase the power of the generic API, and thought there is no point creating ORG bones with raw_copy - functionally they aren't any different from MCH.
This issue was referenced by
b757daf681
