Grease Pencil Vibrating Contours
Needs Triage, NormalPublicKNOWN ISSUE
Graphics card: GeForce GT 740/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.83.4, branch: master, commit date: 2020-08-05 06:00, hash: rBc113af82881a
Hi, i i have bug on Grease Pencil contours. When i move camera in animation contours vibrate, changing size. This is not problem with my PC, because i tried it on another and problem is the same. I tried Anit-Aliasing, change render engine (Cyles and Evee), the same bug is in viewport and in render animation. I'm attach the video of this bug. This bug occurs just with camera or object move.
  1. Create Grease Pencil object.
  2. Move camera to "zoom" it.
Antonio Vazquez (antoniov) changed the subtype of this task from "Report" to "Known Issue".Tue, Sep 15, 5:32 PM
This a know issue with Antialiasing. There are already plans to fix it, but still it's in the ToDo lists.
@Clément Foucault (fclem) do you want merge this in any other task?
@Antonio Vazquez (antoniov) We had this issue with the UV drawing. We can try snapping the points to the nearest pixel to avoid this kind of shimmering. This would be much simpler than trying to have much better antialiasing.
But yes we can merge this to the other task.
Okay. So thank you for answers and i waiting for updates. Btw. when i turned off antialiasing i have the same problem. Is there any chance at the moment to make such a camera move?
@Kacper (kacszu77) I know that @Daniel Martinez Lara (pepeland) had the same issue and he solved render to double size and then scaling down, but he can comment you better how he solved the issue.
