Bevel Tool cycling through percent mode locks numerical input
Confirmed, NormalPublicBUG
Graphics card: GeForce RTX 2080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-07 08:12, hash: rBb351607996e4
In edit mode, if you input a precise value for a bevel (edge bevel tool), like lets say 0,5, and then cycle through the modes (M-key), after cycling past the percent mode, it resets your numerical input to 0, and you cannot change it anymore.
Depending on what value you have input, and whether you have also moved your mouse or not, gives different results. Sometimes it resets to 0, sometimes to another number. In any case, it is then frozen, and you cannot change it.
Version 1, without mouse movement:
  • Add a cube
  • In edit mode, start the edge bevel tool (Ctrl + B)
  • Input a bevel value, like 0,1
  • Press M several times to cycles through modes.
  • The value has reset to 0.
  • Try deleting the input value (backspace) or writing any other number. It is locked.
  • Try moving the mouse. No effect.
Version 2, with mouse movement:
  • Add a cube
  • Move your mouse around
  • The value has reset to some other value, probably based on the mouse position.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Wed, Sep 16, 5:30 PM
Germano Cavalcante (mano-wii) updated the task description. (Show Details)
I confirm that the Percent mode messes up the entered value.
