Shader Viewport Causing System Lag #80799
5 Participants
Reference: blender/blender#80799
Operating system: Linux-5.8.6-1-MANJARO-x86_64-with-glibc2.29 64 Bits
Graphics card: GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.66
System Information Log from Blender
https://gist.github.com/ThisNekoGuy/ca4ae369001899a62b60b84445f5800b
Broken: version: 2.90.0, branch: makepkg (modified), commit date: 2020-08-31 11:26, hash:
0330d1af29
Attempting to use the shader viewport while using Eevee, using my GPU, makes my system go into slow motion until Blender is closed.
It didn't used to do this for me before until just recently. I also attempted to download older Blender versions to see if it would make a difference but it won't fix itself for some reason.
(My main install of Blender is from Manjaro's repo)
I have no idea what could be causing it.
IceCream Cone.blend
https://hdrihaven.com/hdri/?h=derelict_overpass
Added subscriber: @Neko-san
Added subscriber: @mano-wii
I cannot reproduce the problem here.
Try running blender from the command line with the
--debug-gpu
option.After trigger the bug, you can copy information from the command line into a .txt file and attach it here.
Blender Debug-gpu.log
Also, it seems that after waiting a bit, my system becomes responsive again but attempting to interact with the render window causes the system to slo-mo lag again for a while and happens every time.
There is no error or warning message, I'm not sure if these messages will help much.
Have you checked if the drivers are up to date?
To upgrade to the latest driver, see here for more information: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
I already have my latest GPU driver from Nvidia for Linux, I already checked.
Added subscriber: @iss
Can you try build from https://builder.blender.org/download/ ?
Also happened with that version.
Starting to think Nvidia's latest driver might just be bad, because this didn't start happening until recently.
Scratch that, rolling back didn't fix the problem either.
Added subscriber: @lichtwerk
@lichtwerk Can you check this?
No lag/freeze here checked 2.90 and current master
I just tried to do it in Windows on the same hardware (separate drive) without any issue.
I have no idea what's going on here. x_x
Added subscriber: @deadpin
Hi @Neko-san, is this still a problem for you in recent releases like 2.93.0 and when using recent nVidia drivers (version 460 onwards)?
Thanks for the report. If the problem persists please open a new report with the required information.
Sorry for the silence; I was hospitalized recently
It had turned out to be a hardware issue; I had my GPU replaced by EVGA and the issue no longer occured on the new card.
I appreciate the interest in helping solve the issue though, thanks.
