The formula in "Specular BSDF" page of the Blender Manual does not match its examples #80849
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#80849
Graphics card: GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-16 05:28, hash:
blender/blender@7e8cba98b6
Don't know if I can report problems in the manual as a bug but, here is the screenshot:
"specular=((ior-1)/(ior+1))^2" this formula does not match examples like the "water: ior = 1.33, specular = 0.25".
I guess the examples are just simply copied and pasted from the "Principled BSDF" page? The specular formula for the Principled BSDF has a " / 0.08" at the end, which makes the examples valid. But this one does not make sense.
Open this page and you can see it:
https://docs.blender.org/manual/en/latest/render/shader_nodes/shader/specular_bsdf.html
Added subscriber: @Eary
Also this specular value is calculated also from the ior? This specular can turn things into metal when the value is high, and it also has colors, I believe it should not be the same as the specular in Principled BSDF, since the one in Principled BSDF cannot turn things into metal and is only a grey scale value input.
Added subscribers: @fclem, @Blendify
@fclem Can you give some insight here? is the equation wrong or are the values wrong?
The formula is true, and is the same as the fresnel node when the normal and the incident vector are equal.
The issue is the examples values:
This issue was referenced by 7217
