Blender 2.9 render uses 100%gpu but not using cpu
Closed, InvalidPublic
Dell i5 9th gen nvidia gtx1650 4 gb
8 gb ram
512 ssd
Even in rendering it uses 100 percent of gpu but not using any cpu please help me in it.
I am uploading image at this time only blender render is working nothing else.
Thanks please help{F8889678}
Are you rendering with EEVEE? If so, then Blender will only use the GPU.
Yes I rendering with evee. Is gtx 1650 4 gb is not good for rendering in evee?
Alaska (Alaska) closed this task as Invalid.Sat, Sep 19, 9:38 AM
Alaska (Alaska) claimed this task.
Because you're rendering with EEVEE, then only your GPU will be used. Your CPU will not be used for rendering.
For the best performance, you should aim to have your GPU at 100% load in EEVEE, that means EEVEE is taking advantage of your entire hardware meaning faster render times.
Is your GTX 1650 enough? Yes, it meets the requirements to run Blender and will probably remain that way for many years. However, as always, there is always a faster GPU, or set of GPUs, that can offer you better performance.
