Addon - Batch Rename Datablocks - Not searched #80914
Closed
opened 2020-09-18 02:41:26 +02:00 by Jang, Hong-Tak · 4 comments
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
It says to search and use it, but it cannot be searched.
**System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** Addon - Batch Rename Datablocks It says to search and use it, but it cannot be searched. ![Batch rename dadablocks_bug.png](https://archive.blender.org/developer/F8893764/Batch_rename_dadablocks_bug.png) **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @HongTakJang
Member
Added subscribers: @Alaska, @lichtwerk
Member
Try this:
In blender/blender#76227#1008017, @Alaska wrote:
For those experiencing issues with some operators not showing up in the search operator, try these steps:
  1. From the top of Blender select Edit -> Preferences.
  2. From the list of tabs on the right, select Interface.
  3. Now enable the option Developer Extras.
  4. Save your preferences. Now you should be able to find the command you're looking for in the search operator.
This is just a temporary fix. As this task explains, almost everything in Blender should be updated so they're accessable in the search operator without adjusting settings. But until then, this is a work around.
But generally speaking, this is a duplicate of blender/blender#76227 (Make All Operators Accessible from Menus), will merge these reports.
Try this: > In blender/blender#76227#1008017, @Alaska wrote: > For those experiencing issues with some operators not showing up in the search operator, try these steps: > 1. From the top of Blender select `Edit -> Preferences`. > 2. From the list of tabs on the right, select `Interface`. > 3. Now enable the option `Developer Extras`. > 4. Save your preferences. Now you should be able to find the command you're looking for in the search operator. > > This is just a temporary fix. As this task explains, almost everything in Blender should be updated so they're accessable in the search operator without adjusting settings. But until then, this is a work around. But generally speaking, this is a duplicate of blender/blender#76227 (Make All Operators Accessible from Menus), will merge these reports.
Member
Closed as duplicate of blender/blender#76227
2 Participants
Reference: blender/blender-addons#80914
