Bug in particle system - missing particles representations #81103
5 Participants
Reference: blender/blender#81103
Operating system: Linux-5.4.0-47-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX TITAN X/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.44
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
Worked: potentially never, does also not work with 2.80
When creating a particle system with
instance objects
and using more than ~15.000 particles, not all particles are represented with the instance object. The more particles the particle system contains, the more instance objects are missing.The following images illustrate the problem.
Example with 120 x 120 = 14.400 particles. All particles are represented with the instance object (in this case a cube) - except for the first particle at the top left corner. This particle is always missing - even for small particle systems.
For slightly bigger particle systems (e.g. 150 x 150 = 22500 particles), a few particles at random positions in the particle system do not contain an instance object (see the black dots)
For way bigger particle systems (e.g. 200 x 200 = 40000 particles) the last particles (i.e. the particles at the bottom right with the biggest indices are missing)
The presence of particles without instance objects also affects other particles when using specific nodes. For example, when using the
index
output of theParticle Info Node
to compute a texture coordinate for each particle used to compute individual colors for the particles produced strange results.Here a working example for 120 x 120 particles (as reference)
And here a non-working example for 200 x 200 particles (zoomed on the bottom-right corner)
Side note: In all the examples, the particles are there, but the instance object representation is missing.
Execute the following Python script within Blender's text editor. Or, when using Jacques Lucke's VSCode Plugin: execute the script (again) when Blender is already opened (since it does not work with a restricted context)
particle_sys.py
Blend file with the an incorrect particle system
particle_sys.blend
Added subscriber: @sbcv
Added subscriber: @JerBot
Bug in particle system - missing object instances representations of particles results in incorrect node behaviorto Bug in particle system - missing particles representationsAdded subscriber: @iss
I can reproduce this even when I duplicate vertices manually, so script should not influence the result.
The error seems to be unrelated to the instancing itself. It happens in
particle_distribute.c
:See that line 1227 is not executed the expected 39999 times. Instead it is only executed 39967 times. The missing iterations are responsible for the misplaced instances.
There have been multiple attempts to fix this in the past:
950acb0ced
,35ee9ff7a0
.It's a bit crazy that the simplest kind of distribution (one particle per vertex) is hard to implement, currently. The main issue is that this tries to incorporate weights, even if there are none, leading to floating point accuracy issues.
Added subscriber: @2046411367
