Eevee render texture is overlap other objects #81104
Reference: blender/blender#81104
Operating system: Mac Book Pro
Graphics card:
Broken: 2.90.1
The output image shows it + the Blender file of the example.
The array of texture elements are overlapping one the other from Reverse order. when the camera looks on the list of objects you can see the next object is "on" the one closer to the camera.
plant.blend
I used a blank blender file and added the object and textures.
Added subscriber: @Nisim
one more thing, when you look on the element and it looks wrong overlapping and then you press Numpad 9 to get the other side direction, it looks good.
Added subscriber: @mano-wii
I can confirm.
This seems to occur in all versions of blender.
The problem is only seen when
Blend Mode
isAlpha Blend
Added subscriber: @mmoeller
This is currently a documented limitation of Eevee: https://docs.blender.org/manual/en/latest/render/eevee/materials/settings.html#sorting-problem
Geometry is sorted only per-object (based on object origin) for Blend Mode: Alpha Blend. The sample file contains only one single object with transparent geometry. The array modifier on the object just modifies the object, the result is still one single object (with a fixed draw order for blended geometry).
With Blend Mode: Alpha Hashed or Alpha Clip you might get something that is closer to what you try to achieve. But both modes have other limitations (noise for partially transparent parts in the case of Alpha Hashed, and no partial transparency for Alpha Clip).
The result one gets from plant.blend is correct with respect to the documented behavior, so I would classify this as invalid.
Thanks for the info @mmoeller
It is indeed a limitation.
