Operating system: Linux/ppc64
Graphics card: llvmpipe
Broken: 2.83.4, master
Worked: ?
The functions switch_endian_bh4 and switch_endian_bh8 in readfile.c do not byteswap the "old" pointer field. In theory this is fine, as it is just used as an opaque handle, which is mapped to an actual pointer via the OldNewMap. However, in practice this does not work because it seems that the reference pointers to the object are byteswapped, and so if the pointer used as key to create the entry in the OldNewMap is not byteswapped as well, the values will not match and the lookup will fail.
This can easily fixed by just swapping the "old" pointer in the bh swapping functions. That also removes the need for the workaround in bh4_from_bh8. Please see the following patch:
- Start blender on a big endian 64-bit system
- Startup crashes as it fails to load the builtin WM blendfile, getting a NULL back from oldnewmap_lookup_and_inc
