Modifier menu and text switch places #81227
8 Participants
Reference: blender/blender#81227
Graphics card: GeForce GTX 950M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-26 20:04, hash:
8c81b3fb8b
Moving modifiers makes the properties text and modifier menu switch places.
1: Add multiple modifiers
2: Drag to move modifiers
Added subscriber: @AFWS
#81401 was marked as duplicate of this issue
Closed as duplicate of #81161
Added subscriber: @Blendify
This should be fixed, please try an updated daily build.
Seems to be the same or at least related ,but did you look at the date and hash? I just did a
make update
and build the latest 2 hours ago. If that fixed worked, it shouldn't be doing this still.Changed status from 'Duplicate' to: 'Needs Developer To Reproduce'
Based on the description this is not a duplicate of the other report, it would be a different problem.
However, I can't reproduce this. Does it happen if you load the default settings and startup file? (File->Defaults->Load Factory Settings)
It could be the same problem. Does it if you move any panels and not just modifiers. Yeah, I tried Load Factory Settings and it made no difference. Even does it if I open the startup.blend from here
C:\blender-git\blender\release\datafiles\startup.blend
2020-09-27 11-34-40.mp4
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Added subscriber: @iss
@iss I guess you were able to reproduce this? I wonder if it's a windows thing.
Added subscribers: @aicedor, @HooglyBoogly
Added subscriber: @rjg
@HooglyBoogly I can reproduce this behavior as well.
What OS?
Windows as well.
In that case I'd guess that this comes down to platform differences in the implementation of
qsort
. When headerless panels are compared to normal panels they are placed above, but it's sort of arbitrary what happens when two headerless panels are compared. I'm guessing I'll have to tag one of them as "first," although I wonder how it worked in 2.79... Requires a bit more testing. But I have no windows dev setup to reproduce this.@HooglyBoogly That would be a possible explanation of the issue, qsort is not a stable sorting algorithm. From a quick glance at the code this probably means a change to
find_highest_panel
orcompare_panel
?@rjg Yes, probably just switching to a stable sorting algorithm would work. But maybe it's better to fix it more elegantly.
find_highest_panel
is needed to properly sort panels based on where you drag them.There's a variety of small changes to the logic of
find_highest_panel
I would try here. For example, this disables sorting by offset unless one panel in the comparison is being dragged:@HooglyBoogly That change doesn't solve the issue for me. If I have some time later on I'll take another look and see if I can find a solution.
This should be resolved for 2.91. Although I don't have a way to reproduce this, and I only have a few smaller ideas I want to test.
@HooglyBoogly This is not resolved, same behavior as before in master build from today.
@rjg Yes, I meant "I should work on resolving this for 2.91," not that it was already resolved.
@HooglyBoogly Sorry, misinterpreted your comment.
Added subscriber: @MikhailRachinskiy
This issue was referenced by
0724fabcf5
fd78f8699e
