Operating system: Windows10PRO 64bit v2004 (May 2020)
Graphics card: -
Broken: 2.90.1 "stable release", same behaviour also on 2.90 and 2.91(alpha)
Worked: 2.79b, 2.83.6
Opening an older blend file (2.49) exits Blender 2.90.1, but succeeds in 2.79b.
It can be loaded in Blender 2.90.1 if it was saved again in 2.79b
I got this 3D model in a .blend file. When directly opening it Blender 2.90.1 (official release) exits sliently.
Then I opened that file in Blender 2.79b and saved it to another name; Opening that new file then works in Blender 2.90.1
expected behaviour:
although some blend files (even from that old version) open properly its not really surprising that older versions may not work anymore;
BUT: Blender should not silently exit; instead there should be a notification, that (or if possile why) the file cannot be loaded.
Especially for the future this is very important, cause when I now save all my assets as .blend files v 2.90.1 on a DVD,
I want to load them properly also in ten years without being required to convert them all! :)
Consitency of the file format should be the key, shouldn't it?
- Try to open black_head_b3d249_1_v5.blend in any 2.9x version of blender
Here a simplified file (geometry + textures removed and replaced by default cube) saved in 2.49:
Here the same file saved in 2.79 (fixed):
