Botaniq Not Working #81316
Closed
opened 2020-09-30 07:37:52 +02:00 by Don Taylor · 8 comments
Windows 10
Blender 2.901 not working with Botaniq 6.0
Windows 10 Blender 2.901 not working with Botaniq 6.0
Author
Added subscriber: @DonJuanT
Author
Is there something wrong
Author
This comment was removed by @DonJuanT
*This comment was removed by @DonJuanT*
Member
Added subscriber: @ankitm
Member
Ankit Meel self-assigned this 2020-09-30 07:58:20 +02:00
Member
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the template. Please add steps to redo the bug, simple blend file, and a description of the issue.
This report does not contain all the requested information, which is required for us to investigate the issue. Please submit a new report and carefully follow the template. Please add steps to redo the bug, simple blend file, and a description of the issue.
Member
Added subscriber: @Alaska
Member
It should also be noted that the Botaniq is developed by a third party, not the Blender development team. Any issues with the Botaniq add-on should be brought up with the add-on developer.
Reference: blender/blender-addons#81316
