Playback set start/end operators can set rendering range fields to negative frames #81380
Closed
opened 2020-10-02 13:52:37 +02:00 by Tomasz Kaye · 7 comments
Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-26 20:04, hash: 8c81b3fb8b
Original report: The playback/rendering range fields (top right of Timeline view) can't be set to negative frames directly, this should be possible.
This is not a bug
Original report: This range can be set to begin on a negative frame by moving the playhead to a negative frame and then using Timeline > Playback > 'Set Start Frame' button,
This is a bug
  • Enable "Allow Negative Frames" in preferences
  • Try to change the Start field to a number below 0 (it clamps to 0)
**System Information** Operating system: Darwin-19.3.0-x86_64-i386-64bit 64 Bits Graphics card: AMD Radeon Pro 580 OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.5.5 **Blender Version** Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-26 20:04, hash: `8c81b3fb8b` **Short description of error** > Original report: The playback/rendering range fields (top right of Timeline view) can't be set to negative frames directly, this should be possible. This is not a bug ![Screenshot 2020-10-02 at 13.44.30.png](https://archive.blender.org/developer/F8946888/Screenshot_2020-10-02_at_13.44.30.png) > Original report: This range *can* be set to begin on a negative frame by moving the playhead to a negative frame and then using Timeline > Playback > 'Set Start Frame' button, This is a bug ![Screenshot 2020-10-02 at 13.47.09.png](https://archive.blender.org/developer/F8946896/Screenshot_2020-10-02_at_13.47.09.png) **Exact steps for others to reproduce the error** * Enable "Allow Negative Frames" in preferences ![Screenshot 2020-10-02 at 13.50.44.png](https://archive.blender.org/developer/F8946901/Screenshot_2020-10-02_at_13.50.44.png) * Try to change the Start field to a number below 0 (it clamps to 0)
Author
Added subscriber: @info-27
Member
Added subscriber: @lichtwerk
Member
Philipp Oeser self-assigned this 2020-10-05 15:14:21 +02:00
Member
Can confirm some sort of inconsistency.
I assume though that not allowing negative frames for scene render is actually the right thing to do, see the comment in rna_Scene_start_frame_set:
/* MINFRAME ... since some output formats can't take negative frames */
On the other hand, there is the Allow Negative Frames option, introduced in 21a2350248.
This commit claims:
This setting only applies when setting the current frame by scrubbing the time cursor in a timeline view, or by typing a value into the current frame number field.
And the documentation https://docs.blender.org/manual/en/dev/editors/preferences/animation.html#timeline says
Playback and animations can occur during negative frame ranges.
I am reading this as "setting current frame to a negative value should be allowed, setting the preview range to a negative value should be allowed, however setting the scene render startframe/endframe should never be allowed.
But as we can see there are a couple of places where we can end up with negative framenumbers for scene render.
Therefore, this looks like a bug.
(The whole thing might also be considered designed schizophrenia :), but for now lets make sure we dont end up with negative in scene render.)
Related:
  • #42151 (Can't set negative Frame start)
  • #70473 (It is not possible to start at negative frame)
  • #52872 (Toggle "Playback Negative Frames" not working)
Can confirm some sort of inconsistency. I assume though that not allowing negative frames for scene render is actually the right thing to do, see the comment in `rna_Scene_start_frame_set`: ``` /* MINFRAME ... since some output formats can't take negative frames */ ``` On the other hand, there is the `Allow Negative Frames` option, introduced in 21a2350248. This commit claims: > This setting only applies when setting the current frame by scrubbing the time cursor in a timeline view, or by typing a value into the current frame number field. And the documentation https://docs.blender.org/manual/en/dev/editors/preferences/animation.html#timeline says > Playback and animations can occur during negative frame ranges. I am reading this as "setting current frame to a negative value should be allowed, setting the preview range to a negative value should be allowed, however setting the scene render startframe/endframe should **never** be allowed. But as we can see there are a couple of places where we can end up with negative framenumbers for scene render. Therefore, this looks like a bug. (The whole thing might also be considered *designed schizophrenia* :), but for now lets make sure we dont end up with negative in scene render.) Related: - #42151 (Can't set negative Frame start) - #70473 (It is not possible to start at negative frame) - #52872 (Toggle "Playback Negative Frames" not working)
Philipp Oeser changed title from Playback/rendering range fields can't be set to negative frames to Playback set start/end operators can set rendering range fields to negative frames 2020-10-05 15:38:40 +02:00
Member
I have change the task description to reflect what is considered a bug and what isnt.
This issue was referenced by ca38bce46a
This issue was referenced by ca38bce46aa292654451fa34fc33b88fc5ca72f0
Member
Reference: blender/blender#81380
