The 'Vector Rotate' node's 'Angle' input is displayed in degrees but uses radians when something is plugged into it. #81389
10 Participants
Reference: blender/blender#81389
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-29 22:41, hash:
e5aa9decb2
Worked: -
If I don't have anything plugged into the 'Angle' input of the 'Vector Rotate' node I can set the 'Angle' value to be a number in degrees and the vector will be rotated by that many degrees, e.g. set it to 45 and it will rotate the vector 45 degrees. If I plug a 'Value' node set to the same value, e.g. 45, into the 'Angle' input, it will instead use Radians for the rotation and a 'Math' node set to 'To Radians' is needed between the two nodes to get the same result.
The expected result (to me) is that plugging in a 'Value' node set to 45 will result in a 45 degree rotation.
Vector rotate angle bug.blend
Added subscriber: @RayMairlot
#96640 was marked as duplicate of this issue
#98767 was marked as duplicate of this issue
#84374 was marked as duplicate of this issue
Added subscribers: @Blendify, @CharlieJolly, @BartekMoniewski
Mapping node rotation works the same. This is unfortunate but we definitely shouldn't use degrees for vector rotations, they are less practical and would require converting back and forth in complex setups.
Not sure how we could solve it. Any ideas @CharlieJolly ?
Checked documentation of both nodes and it says nothing about this. Adding @Blendify
I'd consider this a UI design issue. The UI shows degrees and this is converted to radians automatically. The property hint could be removed and it would show radians. This is equally unintuitive, e.g. 90 degrees = 1.5708 radians. I think in the first instance this could be added to the documentation.
I agree, this should be documented. In Animation Nodes this is solved by having a "Use Degree" checkbox within a few relevant nodes.
I wouldn't call this a bug, because it is working as intended. There are solutions, but this needs proper design that is outside of the scope of a bug report.
This is a UI issue because properties in Blender can specify there type for example,
PROP_ANGLE
andPROP_NONE
it seems a conversion takes place if to radian if one socket has aPROP_NONE
connected toPROP_ANGLE
. This conversion should either not take place or there should be a way to specify the property type.I addressed this briefly in the documentation with rBM7218 so will leave this to the UI team to address the internal issue.
Added subscribers: @MassimilianoPuliero, @lichtwerk, @filedescriptor
Added subscriber: @tempdevnova
Added subscriber: @zargul
Added subscriber: @Emi_Martinez
