Mirror plane 'Clipping' does not appear to do anything #81417
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#81417
Operating system: win64 / nvidia 1070 / 32 gigs ram
Broken:2.9x
when we apply a mirror to a shape like this
with clipping on I would expect it to act like this
but instead we get this
Added subscriber: @JacobMerrill-1
not_clipping.blend
Added subscriber: @HDMaster84
Clipping is not bisect, and bisect is also not exactly what you seem to want here, but close. Clipping is working correctly in the given example file.
For reference read the manual at https://docs.blender.org/manual/en/dev/modeling/modifiers/generate/mirror.html
Added subscriber: @toctave
Hello! I think you misunderstood what the 'clipping' option does. As it stands, having clipping turned on will prevent you from moving a vertex from one side of the mirror plane to the other.
That being said, what you expected is another feature, that could be added as well. Could you elaborate on potential use cases ? As it stands, I feel like turning clipping on, then moving vertices along the mirror axis so that they sit on the mirror plane is easy enough. Another issue with that feature would be what exactly you mean by clipping : if it's interpreted as an actual boolean difference operation, it might ruin the topology of the mesh, and if it's just projecting vertices on the mirror plane, it could potentially deform it quite a bit.
As I see it, both actions can be accomplished quite easily with other tools (boolean modifier sitting on top, or edit mode manipulations), so there is no need to add complexity to the mirror modifier itself.
"Prevents vertices from moving through the mirror plane(s) when you transform them in Edit Mode."
Ah - I was thinking it did
from what I understand this would be quite a bit cheaper under the hood than bool.
I made a space ship - modified one side, and wanted to remove the other side and mirror the 'good' side.
edit:
ah yes 'bisect' is what I was thinking clip did !!
thank you!
Added subscriber: @JosephEagar
What you want is the symmetrize tool (embarrassingly I just learned about it a few days ago myself). Quite handy.
