Changing a parameter in adjust last operation undoes visibility of the object #81460
Closed
opened 2020-10-05 18:55:55 +02:00 by Andrey · 9 comments
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: 3e85bb34d0
i dont know how to reproduce it.
i only got it once.
Видео 05-10-2020 194433.mp4
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75 **Blender Version** Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash: `3e85bb34d0` Worked: (newest version of Blender that worked as expected) i dont know how to reproduce it. i only got it once. [Видео 05-10-2020 194433.mp4](https://archive.blender.org/developer/F8958401/Видео_05-10-2020_194433.mp4)
Author
Added subscriber: @QazQwer
Added subscriber: @StephenSwaney
Do we know what the problem is?
Member
Added subscriber: @EAW
Member
When you change any parameter in the Adjust Last Operation panel, it will reset the state Blender was in when that operation was first done.
Question is, is this documented anywhere?
When you change any parameter in the *Adjust Last Operation* panel, it will reset the state Blender was in when that operation was first done. Question is, is this documented anywhere?
Ankit Meel changed title from not that important to Changing a parameter in adjust last operation undoes visibility of the object 2020-10-06 15:59:32 +02:00
Added subscriber: @mano-wii
This report does not contain all the requested information, which is required for us to investigate the issue.
It is missing:
  • Exact steps for others to reproduce the error
  • A blend file (unless there are simple steps to redo this from the default startup).
I couldn't find out what the steps were through the video.
Some apparently related bugs have already been reported:
  • #69760 (Undo/Adjust Last Operation: vertex and weightpaint operators/strokes undo more then they should (change back any setting changed prior to execution))
  • #75013 (Incorrect order in undo stack when switching between Object Mode and Edit Mode)
  • #73612 (Inset faces and Bevel Edge command has bugged interaction with Undo command and shape keys)
  • #50423 (Adding new hook while in Edit mode breaks when trying to undo/redo the operator)
Is this a duplicate?
There is also a task to improve the undo system:
  • #56163 (Improve MemFile Undo (for general use))
This report does not contain all the requested information, which is required for us to investigate the issue. It is missing: - Exact steps for others to reproduce the error - A blend file (unless there are simple steps to redo this from the default startup). I couldn't find out what the steps were through the video. Some apparently related bugs have already been reported: - #69760 (Undo/Adjust Last Operation: vertex and weightpaint operators/strokes undo more then they should (change back any setting changed prior to execution)) - #75013 (Incorrect order in undo stack when switching between Object Mode and Edit Mode) - #73612 (Inset faces and Bevel Edge command has bugged interaction with Undo command and shape keys) - #50423 (Adding new hook while in Edit mode breaks when trying to undo/redo the operator) Is this a duplicate? There is also a task to improve the undo system: - #56163 (Improve MemFile Undo (for general use))
Closed as duplicate of #69760
Reference: blender/blender#81460
