unexpected gusts of wind in gas flow simulation #81493
6 Participants
Reference: blender/blender#81493
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
A simple setup with a steady jet is seeing unexpected strong gusts of wind.
Background
I use high initial gas velocities creatively as a rocket exhaust. High velocities give in this case a much better visual effect compared to slower. I want a relatively steady and centered gas jet. However the strong gusts from boundaries are severly disturbing rocket plume and the visual appearance.
I tried the following changes to improve convergence/accuracy/stability.
a. Cube fluid settings: CFL Number 0.5
b. Cube fluid settings: Timesteps Maximum time steps 20
c. Cube fluid settings: Timesteps Minimum time steps 4
d. Plane fluid settings: Sampling substeps 4
e. Plane fluid settings: Flow Source, set IsPlane to true
The strong gusts still occured with these changes.
Ideas for fixing
Test File
gustofwind.blend
Added subscriber: @jdk
Added subscriber: @mano-wii
Thanks for the report,
I believe that the problem would be more easily reproducible with a simple .blend file.
If there are many steps to reproduce the problem, it is recommendable to attach a .blend file saved right before the bug occurs, so only a few steps are needed to trigger the bug.
Can you provide this?
Here is the blend file.
gustofwind.blend
You need to rebake or download files here (640MB)
https://drive.google.com/drive/folders/1XpdRR4ok14nvS95BHZwpkGio8twAYiD4?usp=sharing
The gust happens around frame 120
Let me know if I can help more.
Added subscriber: @deadpin
Hi @jdk, I was able to bake all 300 frames from your example file using 2.93.0 today and things seem fine. I did not observe any strong gusts of wind, just a relatively constant stream of smoke downwards. Can you try reproducing your problem using 2.93.0 or later? If it's still a problem, can you post a screenshot of the frame that exhibits the problem as well as the frame just before perhaps (or whatever might show the difference)?
Hi @deadpin,
I cannot recreate the issue of sudden gust either. So I guess it has been fixed somehow. Problem solved I guess.
Changed status from 'Needs User Info' to: 'Resolved'
Thanks for checking. If you encounter a similar problem please feel free to create a new report on the issue.
