Threshold of the 'Select Similar' operator (Shift G) is very limited at large scales. #81542
Reference: blender/blender#81542
Hi,
since I'm working on a project in Unreal Engine it needs to be actually done in centimeters (meaning in mesh-terms it's 100 bigger than meter mesh).
Here is the blend file: ShiftG_SelectSimilarArea_CantPutInMoreThan1.000.blend
Try to select a face and Shift+G -> Select Similar (not sure if the shortcut stayed that way)
I'm running into an issue here and there where some functions expect the mesh to be in meters and work worse in centimeters (or not at all)
For example here I was using Shift+G and Area to get the faces with the same area. Because the areas in the centimeters model are so big number-wise it doesn't find any match. So either I think the amount needs to be unlimited (I would put in 100 and that would probably have the same results as when the mesh is 100x smaller) or this needs to be addressed from the unit scale side of things.
This is in Meters (scaled the mesh 0.01), we get a good window selection because they are mostly the same:
And in Centimeters nothing more than the one face is selected.
Maybe the scale in Units should be used in these operators to make the mesh smaller?
Thanks for looking into this.
Added subscriber: @AdamPreisler
Added subscriber: @mano-wii
We could make the threshold value unlimited, but we cannot set a unit for it, since this unit depends on the "type" property (which can be Area, Length or Angle).
Unfortunately, if I'm not mistaken, there is no API to change the subtype of one property depending on another.
It is really inconvenient to limit the threshold value to 1.0.
So I'm marking this report as TO DO (Papercuts).
Using Shift+G (Select Similar) is broken when using different units than default metersto Threshold of the 'Select Similar' operator (Shift G) is very limited at large scales.Added subscriber: @erik85
I tried to fix this in a simple way by multiplying the threshold value with the value that is compared against. And if delta is negative, the threshold is multiplied by 0.5 to make the range between 50% smalller to 100% bigger. Do you see any problems with this? Will it mess with any other select similar modes?
