SSS Shader - Black artifacts with intersecting geometry within the same object #81602
5 Participants
Reference: blender/blender#81602
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-19 23:28, hash:
874af5301c
While rendering with Cycles using the random walk subsurface scattering parameters I do get black lines/artifacts wherever there is intersecting geometry even when it's the same object. An option where it's possible to define which objects should be treated as one volume for the SSS calculations would be great (and probably treating one object that contains several geometries that are intersecting as one volume). I wasn't sure if that is a feature request or a bug but I don't see a case where that is preferable so I reported it as a bug.
As a test I duplicated the default cube and moved it so the two cubes intersect. I then joined the cubes into one object. I set the subsurface method to 'random walk' and the subsurface slider to '1'. Cycles is used and I added a simple Area light above the cubes to see it better.
Attached is the quick test scene with the cubes and a render comparison between cycles in blender and the SSS random walk 2 in maya with arnold (the one with the black edges around the muscles is done with blender/cycles and the clean one is done with maya/arnold)
SSS_blackArtifacts_test.blend
Added subscriber: @FynnGB
#85202 was marked as duplicate of this issue
Added subscribers: @brecht, @iss
I think that this has not much in common with #56914. Not sure though if what @brecht said applies to objects or "mesh groups" like in this case.
From the docs:
The description could perhaps be improved, but the point is that there must be a clear inside/outside for volumetric scattering, and with overlapping cubes as in the example file that is not the case.
thanks for the replies! @brecht Should I post it as a feature request (as mentioned in the other task)? Or is this request already posted?
Thanks a lot!
Added subscribers: @Joe_W, @DarkKnight
