Crash on Exiting Texture Paint With Multiresolution (Image Editor involved) #81775
7 Participants
Reference: blender/blender#81775
Operating system: Windows 10 64 bit
Graphics card: Nvidia GTX 750 Ti
Broken: 2.90.1 release, 2.91 alpha
ba8233174c
Worked: 2.83.7
Introduced by: {1ceb91d1b3947fda67a70a2eff785a964e625ca2}
Switching from Texture Paint mode to Object Mode with an object that has a Multiresolution modifier, after sampling and then painting, crashes every time.
This makes Texture Painting with Multires impossible to use.
texturepaint_exit.blend
Added subscriber: @Foaly
#80560 was marked as duplicate of this issue
#82298 was marked as duplicate of this issue
#81605 was marked as duplicate of this issue
Added subscriber: @EAW
Thank you for the report. I can confirm that it crashes using 2.91
77aef03d8a
.It crashes 2.90.1 when starting Blender normally, or when using
blender_factory_startup.cmd
. 2.90.1 doesn't crash when usingblender_debug_log.cmd
orblender_debug_gpu.cmd
2.83.7 doesn't crash.
2.91 MSVC debug build stack trace:
{F9010015}
{F9010016}
{F9010063}
Slightly different stack trace when running
on a Release build:Note that the crash doesn't seem to happen if there is not Image Editor open.
And should this perhaps be High priority, considering this is a crash bug? (See https://wiki.blender.org/wiki/Process/Bug_Reports/Triaging_Playbook#Valid_crash_report.2C_can_confirm)
Added subscriber: @lichtwerk
I am seeing this as well (not reliably though, still trying to figure out how exactly this can be triggered 100% reproducable)
Also I dont get in a Debug build at all?
For Release builds, this seems to have started between good
baf124c753
and badf45f8a7a89
.So no luck nailing this to a particular commit that caused it, but I also think this deserves High priority.
Crash on Exiting Texture Paint With Multiresolutionto Crash on Exiting Texture Paint With Multiresolution (Image Editor involved)Added subscriber: @Jeroen-Bakker
@Jeroen-Bakker: does this ring a bell?
Added subscribers: @Diogo_Valadares, @iss, @mano-wii
I agree that it should have been set to high, I wanted to see if I could narrow down the cause further first. I got caught going down the rabbit hole of the fact that many seemingly unrelated crash reports stack traces all start with the same TBB code (that partially(?) has since been removed from their code base. (Difficult to figure out what is going on there as TBB's commit logs leave much to be desired in the documentation and size department.))
I did try retest this yesterday using 2.91
efc2edc47f
and noticed that it no longer crashes when changing to object mode. However, the sphere now disappears when I click to paint on it.Running
results in 227 occurrences of:GPUDebug: [2mTexture state usage warning: Texture 0 is base level inconsistent. Check texture size.[0m
and 8 occurrences of:
GPUDebug: [2mRasterization usage warning: Blending is enabled, but is not supported for integer framebuffers.[0m
blender_debug_output.txt
blender_system_info.txt
I'd also like to note that the root of the issue seems to be happening at the sampling (pressing S).
You can see that in the image editor the lines from wireframe disappear and it looks like it's drawn with "optimal display".
I will have a look as my name is all over it :-) Not sure what is actually going on. But will investigate starting with the drawing part.
I am not able to crash. It could be that the crash has already been solved. Still left are the glitches.
In Blender 2.83 the uv geometry in the uv editor also changes, will add that as a separate issue. I will keep this issue for the disapearing object.
I can confirm that this no longer crashes, but the object disappears instead.
yes, as evan said
The disappearing object is introduced by {1ceb91d1b3947fda67a70a2eff785a964e625ca2}
It seems like
draw_cache_impl_mesh
perfors a save clearbut the
MBC_SURFACE
batch isn't picked up bymesh_buffer_cache_create_requested
.Added subscriber: @Manndarinchik
This issue was referenced by
7a7f294940
Added subscribers: @Ekiwnox, @rjg, @brecht, @coindrop, @ankitm
