Splash Screen can not be closed #81925
6 Participants
Reference: blender/blender#81925
Graphics card: Quadro RTX 4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-20 03:39, hash:
efc2edc47f
Worked: 2.90
Very similar behavior to #58692 - Basically I can not close the initial splash screen, the click on the button does absolutely nothing:
The reason could again be that we use the environment variables BLENDER_USER_CONFIG, BLENDER_USER_DATAFILES and BLENDER_USER_SCRIPTS to share our Blender settings within the company. However, BLENDER_USER_CONFIG is unique for every user we have, whereas the other two are identical for each user.
Set the aforementioned variables to a network drive location (on Windows) and start Blender. Should see the behavior described in the GIF.
Added subscriber: @RainerTrummer
Added subscriber: @rjg
In the other ticket (#58692) you state that the issue was recently introduced to 2.91. Do you know of a previous version of 2.91 that didn't have this issue? That could help to narrow down which commit caused this change in behavior. Does this happen with any network drive or only under specific circumstances, e.g. if there is a large latency or the network drive fails to respond?
Added subscriber: @Harley
Is this really that the splash won't close or about the initial setup not running?
The gif shows clicking on the "Next" button and within the empty dark grey area. But the grey area should do nothing. Closing of the dialog should occur if you click on the splash image itself or anywhere outside the dialog. Does it close if you do either of those things?
Added subscribers: @ideasman42, @brecht
@ideasman42, this is caused by
6f3a9031f7
.The underlying issue can be reproduced like this, there's an invalid string coming from the Python API:
The bug is caused by the change to
test_env_path
. The commit introduced the following part:This change causes the function to return before
env
is copied topath
. If the intention was to skip theBLI_is_dir(env)
check in the function, then it should have still called theBLI_strncpy(path, env, FILE_MAX);
.Call stack of the old code:
The call to
test_env_path
copies the path of the environment variable intouser_path
.Call stack of the new code:
In this call
check_is_dir
isfalse
andtest_env_path
returns early, failing to setuser_path
.This issue was referenced by
e1eaf9e2b4
ef5d6e9c45
