Boolean issues when duplicating and rotating mesh or object #82047
Reference: blender/blender#82047
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.30
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-10-23 17:33, hash:
70cc0d7121
Not sure if this is a boolean issue or an issue with accuracy when rotating. Scale a cube in the x or y direction, duplicate that cube and rotate it along the z-axis 90 degrees forming an X. Apply a boolean difference on it using the new algorithm and swap between the two. One will completely subtract the other but not the other way around. But if you move one cube in the z direction and snap it back it will boolean each other correctly.
Or
boolean_rotated_box.blend
Cube
Added subscriber: @RobbieK
Added subscriber: @Foaly
I cannot reproduce.
Following your instructions, everything works correctly.
Please upload a file that illustrates your issue.
I tried it with bool tool in object mode and it worked this time for some reason. Scale the cube in edit mode and use boolean intersect and you get the issue.
It should look like this.
Update 1: I figured out why it didn't work in object mode last time. I separated one of the meshes and tried bool tool on both objects and it had the same problem. But moving one object in the z direction and snapping it back didn't fix the issue in object mode like it did it edit mode.
Update 2: I tried it again in edit mode and moving one mesh in the Z direction and snapping it back no longer works to fix the problem anymore.
Update 3: Snapping the upper and lower faces of one mesh to the other fixes the problem.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @howardt
I can confirm with 2.92.0 alpha
e4728d0a16
The following file shows the issue.
@howardt I think this is for you.
boolean issues when duplicating and rotating mesh or objectto Boolean issues when duplicating and rotating mesh or objectChanged status from 'Needs Developer To Reproduce' to: 'Confirmed'
This seems to have been fixed in part recently.
However, if the box is scaled up a bit, and the boolean is applied multiple times, it can still cause issues.
See the attached file.
boolean_rotated_box2.blend
The box with diagonals in boolean_rotated_box2.blend has y values that are almost, but not exactly +1 or -1. Here are the exact vertex coordinates (followed by what printing them as floating point gives):
2826879/524288 16777165/16777216 -1 # 5.39184 0.999997 -1
11307515/2097152 -4194317/4194304 -1 # 5.39184 -1 -1
2826879/524288 16777165/16777216 1 # 5.39184 0.999997 1
11307515/2097152 -4194317/4194304 1 # 5.39184 -1 1
6053245/8388608 16777209/16777216 1 # 0.721603 1 1
756655/1048576 -8388611/8388608 -1 # 0.721602 -1 -1
So the two cubes do not line up in a way to give a nice cube-like intersection, and I don't see a bug here.
In general, when you do rotates and scales, the coordinates are multiplied by matrices with floating point values and it is to be expected that even though you think an operation should not affect a particular coordinate, it can do that in minuscule ways. I'm going to close this now. Feel free to reopen if there's a case where the input coordinates exactly line up (in this case: all y and z values should be exactly the same on both objects) and boolean fails.
Maybe there is a misunderstanding here:
I'm not talking about the long stretched flat faces that remain, the issue is that a part of the mesh on the right disappears.
Otherwise, can we define the cases in which the exact boolean is supposed / not supposed to work then?
All the meshes in the example are manifold, but the boolean cuts away pieces that are not within the "brush".
If the self option is enabled, the resulting mesh is no longer manifold.
I am seeing this as the result:
I don't know what you mean by "part of the mesh on the right disappears".
If Cube had x and z values that exactly matched those of Cube.001, then we would expect that the whole center section would be gone when you subtract Cube from Cube.001. Since that isn't true, one has to examine the topology carefully to find out what parts of space are inside Cube.001 and not inside Cube. It is plausible to me that the two flat pieces in the middle are the parts of space that satisfy that, though I admit I didn't carefully verify that.
I've been checking this with the latest builds from the buildbot: 2.91 beta 46da8e9eb958-windows64, 2.92 alpha 7be47dadea50-windows64.
I also built the latest master
39012146e1
myself.What build are you using?
This is what I see in boolean_rotated_box2.blend in all 3 cases:
@howardt Can this be reopened? I'm still getting the same wrong result with the latest 2.91 beta (2.91.0 4960780d76bf-windows64).
