Can't do anything in local view under certain circumstance
Operating system: windows 10 pro 2004
Graphics card: GTX 970
Broken: 2.90.1
Worked: none
If you local view an object and accidently press number keys(solo other collection). Than you can't do anything to the current object.
Local view the object, than go into the edit mode and hit 1,2,3 to switch vertex, edge, face is a high high-frequency operation. Chances are high that the number keys are also pressed in object mode, too. Which will causes the freezing and frustrating what happened. The collection solo mode is barely noticeable. It's very likely to thought that Blender is frozen or crashed.
IMHO. Hide or solo collection doesn't need a shortcut, especially with the number keys only. If insist, alt+1234 maybe a better idea or something else.
  1. open the default file.
  2. create some new collections.
  3. choose the default cube and press '/' button to go local view.
  4. press 2 or 3 or 4(solo corresponding collection). Than the current object is frozen.(can't move, can't edit, etc.)
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Oct 27 2020, 9:13 PM
I cannot reproduce this with either the latest stable or current development versions of Blender:
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Philipp Oeser (lichtwerk) closed this task as Archived.Nov 18 2020, 2:33 PM
