MetaBalls do not get evaluated
Group: current SVN version
Resolution: Approved
Category: Tools
Effects of negative Metaballs do not get evaluated in
ALT-A preview if the Metaball is a child of an animated
object.
It DOES get evaluated in Animation render, though.
Test: Create a Meta plane. Create an UVsphere. Create a
negative Metaball in the UVsphere to make the UVsphere
deform the meta plane, make the UVsphere parent of the
Metaball. Animate the UVsphere diving into the metaplane.
The Metaplane will not be influenced by the Metaball in
ALT-A.
Ton Roosendaal (ton) closed this task as "Archived".Apr 8 2004, 1:55 PM
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
