Add-on tab don't appears in preferences #82325
Reference: blender/blender#82325
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.90.1, branch: master, commit date: 2020-09-23 06:43, hash:
3e85bb34d0
Add-on tab don't appears in preferences. I can't active, dissable or install add-on.
Open one blender version: 2.83.8 or 2.901.1 or 2.91, edit, preferences, addóns is empty
failtest.blend
Added subscriber: @FranciscoJoseNavarroSanchez
Added subscriber: @dupoxy
This report looks like #82287. Could be the same problem to find.
You could try loading factory settings if you have not done so.
Added subscriber: @rjg
This issue is most likely caused by a permissions error and/or broken add-on installation.
Please open Blender's installation directory and double click on the
blender_debug_log.cmd
. This will start Blender in debug mode and create log files. Open the add-on preferences again, then close Blender. The Windows Explorer should open and show you up to two files, a debug log and the system information. Add them to your bug report by clicking on the upload button as shown in the screenshot below or via drag and drop.Please also try to temporarily load the factor default setting by opening Blender's installation directory and double clicking on the
blender_factory_startup.cmd
. Check if this allows you to open the add-on preferences. Be careful though, do not save the preferences, as this would overwrite your existing ones with the factory defaults (unless you intend to do that).If you don't care about saving your current user preferences and add-on installations or the factor startup has no positive effect, then you could rename or delete the
C:\Users\[your username]\AppData\Roaming\Blender Foundation\Blender\2.90
directory (replace[your username]
with your actual username). This may be necessary if the problem is caused by a permission error and you don't want to check and correct the permission on every file in this directory.Changed status from 'Needs Triage' to: 'Needs User Info'
Thank you very much. I test it in one version of blender file 2.91 but the error take place in all other versions. Regards.
blender_debug_output.txt
blender_system_info.txt
@FranciscoJoseNavarroSanchez you have several warnings about add-ons in the log file.
Please rename
C:\Users\Fran J. NS\AppData\Roaming\Blender Foundation\Blender\2.91
toC:\Users\Fran J. NS\AppData\Roaming\Blender Foundation\Blender\2.91-orig
. Start Blender again and check if the preferences display correctly.@FranciscoJoseNavarroSanchez Did my suggestion in the previous comment solve the issue for you? The issue is most likely caused by an add-on for instance due to an improperly formatted
bl_info
as reported in #82287.Changed status from 'Needs User Info' to: 'Archived'
