Is node collection ordered? #82350
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
2 Participants
Reference: blender/blender-manual#82350
I actually have found that it is and it represents selection order. Probably it is worth mentioning in the documentation if it is going to be persistent between Blender releases?
https://docs.blender.org/api/current/bpy.types.Nodes.html
Added subscriber: @randum
Right, the nodes are ordered so that last selected node is at the end. This way it is drawn last, i.e. at the top. I don't really want to document this behavior though. I don't want anyone to rely on this order. See
ED_node_sort
for more details.Well I was going to rely on it. I have the problem of determining of active output node of a group tree. There is
tree.active_output
attribute which looks doing nothing. It always (almost) points to last node in node collection (my guess). I think its purpose is to be corrected manually so it could point to any you like.With assuming that nodes collection is order this task becomes simple I just have to find last output node in nodes collection. Otherwise I was thinking about adding
draw handler
to node tree to track nodes selection but I would like to avoid this solution if possible. Are you going to change this behavior soon?You might be able to use the
is_active_output
property of output nodes. And yes, I think the active node is set by simply selecting the node. Since this node is also the active node, it will be moved to the back of the nodes list. So you can kinda depend on this fact for now, but I won't promise nor document that this won't change in a future release.The
tree.active_output
selects the active output socket I think, not the active output node.
