Cleanup 1st Sprint Nodes #82370
5 Participants
Reference: blender/blender#82370
For the first sprint a few nodes were added to get familiar with the code.
However they are not complete
Transform: could use rotation order setting(that can be added later when necessary)Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @dfelinto
Added subscriber: @PiloeGAO
@PiloeGAO hi, maybe you are interested on helping with this one?
(we plan to tackle this in the next sprint, so usually it is not something I'm comfortable leaving for the community. That said if you think you have the time we could try it.
I actually purposefully left this out. I think the interface is simpler if you just set the angle to 180 degrees if you don't want to use edge angle. That or an enum type at the top of the node that would control between the angle or using sharp edges.
And for some background for @PiloeGAO, we talked about removing simple because there are plans to remove this from the modifier and related code in the future, and removing optimal display because there are other considerations about where to expose display options for evaluated geometry that still need to be thought out properly for geometry nodes.
It will be a true honor to contribute again. I have some free time so I could spend time on that.
@dfelinto hi, I made a differential request for subdivision surface inputs. You can find it here: https://developer.blender.org/D9487
I made a new diff for the triangulate node (I added missing enums). You can find it here: https://developer.blender.org/D9502
@dfelinto Hi, I plan to spend time on this task this weekend (and hopefully finish it). But I have some questions/suggestions:
@PiloeGAO re: "Combine Strings" and "Group Instance ID": If a node is useless for now, then it shouldn't be there. There is no point to the users to see that in the UI if the node cannot be used. They should even be removed individually (or hidden from the UI) so it is easy to bring them back one by one if needs be.
The reasoning is that at any moment we should be able to stop the tasks we are working on and deploy the product. If we have lingering features that are not complete, not usable, ... this gets on the way.
We were a bit more relaxed with this in the first sprint, but as part of the preparation to master in the upcoming sprint I want to see this mindset in everyone involved.
@PiloeGAO: Re: rotation order I think it is a good idea (cc @JacquesLucke )
@HooglyBoogly re: Edge Split I see no reason why to deviate from what we do in the modifier:
I don't expect users that only want to split the sharp edges to realize that an angle of 180 leads to no split.
I thought we had already talked about that before create this task no? Were you not in the meeting, or did you just change your mind since? (or didn't consider all the angles).
If you are serious about proposing that can you also investigate when was this introduced, and what was the reasoning to have this as a separate option?
Re: rotation order
I'm not sure if this should be a setting on the node, a separate input, or whether this should be part of the rotation input.
E.g. in Animation Nodes there is a separate socket type for Euler rotations that combines a 3d vector with a rotation order (you rarely have to deal with the rotation order though).
I guess for now it's fine if it is just a setting in the node. It can always be exposed as input later when necessary. The versioning code for this should be relatively straight forward.
I made a diff request for removing "Combine Strings" and "Group Instance ID" from UI, you can find it here: https://developer.blender.org/D9558
The diff for the Edge Split node is available here: https://developer.blender.org/D9564
Added subscriber: @skartemka
Removed subscriber: @skartemka
I made some researches last weekend for the transform node but I found nothing working and/or efficient.
@JacquesLucke may found a better way to implement it.
