Viewport Rendering and Texture Baking freezes Blender #82483
5 Participants
Reference: blender/blender#82483
Operating system: Windows 7 64bit
Graphics card: GTX 1660 Super
Broken: 2.90.1
Worked: 2.83
Worked: builds prior to
b21ba5e579
Blender freeze when baking ambiant occlusion
I prepared my scene to bake all objects, but almost every time I try to bake an object (especially the table under the tv), blender is often stuck at 0%, using high CPU usage and freeze.CtUrban.blend
Update: Viewport Rendering also crash Blender.
Added subscriber: @Snake1726
Added subscriber: @lichtwerk
This is due to the Margin being too large (it writes into other islands).
Should not freeze of course, so would assume this is a bug, checking further.
Blender freezing when baking ambiant occlusionto Texture Baking freezes if margin is too large and writes into other islandsFor me, this broke somewhere between
b21ba5e579
andf2b5f731d5
Maybe
99436acde8
?While bisecting I was also seeing (not sure if this is related to)
Not sure if margin has to do with it though, I can also get it to freeze with zero margin
Texture Baking freezes if margin is too large and writes into other islandsto Texture Baking freezesChanged status from 'Confirmed' to: 'Needs User Info'
There is something wrong with the
urban
guy.If this object is disabled in viewports and rendering, baking seems to go fine.
(will try to contiue investigations tomorrow)
I havent been able to figure out what exactly it is that makes baking fail in this situation, but can you confirm that it works with this objects excluded/deleted?
Hrmf, testing further, this [
urban
guy is the culprit] is also not true, will try to profile now where it hangsASAN will not show any errors, this sometimes goes right the first time, then freezes on a second try (so situation is not even the same in the same build).
Added subscriber: @brecht
I'm unable to reproduce this, testing:
I just tried again today with Blender 2.91.1 and 2.92 beta, it crashed after 1-3 attempts to bake textures (AO and Lightmap). I also noticed that the problem only occurs when all objects are selected for rendering, Blender doesn't seem to hang when ignoring objects from the render and baking 1 by 1.
Update: Blender also crash when rendering viewport so this is not related to baking textures as I thought.
Texture Baking freezesto Viewport Rendering and Texture Baking freezes BlenderChanged status from 'Needs User Info' to: 'Needs Triage'
Will have to check again
Added subscriber: @leesonw
I tried this today and noticed 2 things. The first time I tried to bake it started to compile all the kernels which can take a while then I tried selecting many objects and backing them at some point I got the following
intern/cycles/device/cuda/device_impl.cpp
I am guessing we are either freeing some already freed memory or this was an uninitialised pointer. On machine machine this does not cause a crash but it does cause all the CUDA stuff in blender to just stop working which may be the cause of the issue.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
@leesonw : not sure what you got there? (seems incomplete)
If I read this right, you were able to repro an issue at that point in time.
Can you still repro?
I am the original op, this issue is still really frequent. Freezing on almost every bake (Blender 4.0 and Blender 4.1 RC)
Is this issue going to be adressed one day?
Thx
Here is my blend scene where it freeze on almost every bake. Open it and hit Bake those 3 cube. After 3-4 bake, blender will freeze.
