Volume Object crash is back... this time with NanoVDB #82516
Closed
opened 2020-11-08 23:53:27 +01:00 by Steffen Dünner · 7 comments
Operating system: Linux-5.8.0-25-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.32.00
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-08 15:12, hash: 39012146e1 <- Own compile with NanoVDB
Worked: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-08 15:12, hash: 39012146e1 <- Own compile without NanoVDB
Some days ago I reported a crash bug that got fixed here: https://developer.blender.org/rB6a2a6fa5143e7b115c47b8e2ef4787f569c670df
But I noticed that with my builds it still crashes while the Buildbot builds are stable.
I then recompiled a build without the (still unsuppported?) NanoVDB and it's as stable as the one from the Buildbot. So, is this even a "legal" bug report? If not, just ignore it.
BTW this crash only seem to be happening when a VDB is involved in opposite to the one I reported before where a simple Volume Object would crash Blender. It now also takes a frame change to cause the crash.
  • Download and extract the ZIP
    Volume_Crash_v02.zip
  • Open the Blend file and press Z + up (or whatever way you prefer to start preview render in the viewport).
  • Use the mouse to click around in the timeline to change the current frame. I noticed that when you use the right and left arrow key it's much harder to crash Blender.
  • It only crashes with builds using the NanoVDB option, at least as far as I tested it.
**System Information** Operating system: Linux-5.8.0-25-generic-x86_64-with-debian-bullseye-sid 64 Bits Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 455.32.00 **Blender Version** Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-08 15:12, hash: `39012146e1` <- Own compile with NanoVDB Worked: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-08 15:12, hash: `39012146e1` <- Own compile without NanoVDB **Short description of error** Some days ago I reported a crash bug that got fixed here: https://developer.blender.org/rB6a2a6fa5143e7b115c47b8e2ef4787f569c670df But I noticed that with my builds it still crashes while the Buildbot builds are stable. I then recompiled a build without the (still unsuppported?) NanoVDB and it's as stable as the one from the Buildbot. So, is this even a "legal" bug report? If not, just ignore it. BTW this crash only seem to be happening when a VDB is involved in opposite to the one I reported before where a simple Volume Object would crash Blender. It now also takes a frame change to cause the crash. **Exact steps for others to reproduce the error** - Download and extract the ZIP [Volume_Crash_v02.zip](https://archive.blender.org/developer/F9241295/Volume_Crash_v02.zip) - Open the Blend file and press Z + up (or whatever way you prefer to start preview render in the viewport). - Use the mouse to click around in the timeline to change the current frame. I noticed that when you use the right and left arrow key it's much harder to crash Blender. - It only crashes with builds using the NanoVDB option, at least as far as I tested it.
Added subscriber: @SteffenD
Now that NanoVDB is enabled by default, this bug will hopefully be confirmed as soon as the Buildbots are updated tonight.
Added subscriber: @iss
I can reproduce crash with nanoVDB
>	[Inline Frame] blender.exe!ccl::BVH::pack_triangle(int) Line 271	C++
 	blender.exe!ccl::BVH::pack_primitives() Line 307	C++
 	blender.exe!ccl::BVH::refit(ccl::Progress & progress) Line 189	C++
 	blender.exe!ccl::Geometry::compute_bvh(ccl::Device * device, ccl::DeviceScene * dscene, ccl::SceneParams * params, ccl::Progress * progress, int n, int total) Line 222	C++
 	[External Code]
 	[Inline Frame] blender.exe!std::_Func_class<void>::operator()() Line 951	C++
 	blender.exe!tbb::internal::function_task<std::function<void __cdecl(void)>>::execute() Line 1049	C++
 	[External Code]
 	[Inline Frame] blender.exe!tbb::task::wait_for_all() Line 809	C++
 	blender.exe!tbb::internal::task_group_base::wait() Line 168	C++
 	blender.exe!ccl::TaskPool::wait_work(ccl::TaskPool::Summary * stats) Line 46	C++
 	blender.exe!ccl::GeometryManager::device_update(ccl::Device * device, ccl::DeviceScene * dscene, ccl::Scene * scene, ccl::Progress & progress) Line 1571	C++
 	blender.exe!ccl::Scene::device_update(ccl::Device * device_, ccl::Progress & progress) Line 266	C++
 	blender.exe!ccl::Scene::update(ccl::Progress & progress, bool & kernel_switch_needed) Line 502	C++
 	blender.exe!ccl::Session::update_scene() Line 1029	C++
 	blender.exe!ccl::Session::run_cpu() Line 789	C++
 	blender.exe!ccl::Session::run() Line 864	C++
 	blender.exe!ccl::thread::run(void * arg) Line 53	C++
 	[External Code]
I can reproduce crash with nanoVDB ``` > [Inline Frame] blender.exe!ccl::BVH::pack_triangle(int) Line 271 C++ blender.exe!ccl::BVH::pack_primitives() Line 307 C++ blender.exe!ccl::BVH::refit(ccl::Progress & progress) Line 189 C++ blender.exe!ccl::Geometry::compute_bvh(ccl::Device * device, ccl::DeviceScene * dscene, ccl::SceneParams * params, ccl::Progress * progress, int n, int total) Line 222 C++ [External Code] [Inline Frame] blender.exe!std::_Func_class<void>::operator()() Line 951 C++ blender.exe!tbb::internal::function_task<std::function<void __cdecl(void)>>::execute() Line 1049 C++ [External Code] [Inline Frame] blender.exe!tbb::task::wait_for_all() Line 809 C++ blender.exe!tbb::internal::task_group_base::wait() Line 168 C++ blender.exe!ccl::TaskPool::wait_work(ccl::TaskPool::Summary * stats) Line 46 C++ blender.exe!ccl::GeometryManager::device_update(ccl::Device * device, ccl::DeviceScene * dscene, ccl::Scene * scene, ccl::Progress & progress) Line 1571 C++ blender.exe!ccl::Scene::device_update(ccl::Device * device_, ccl::Progress & progress) Line 266 C++ blender.exe!ccl::Scene::update(ccl::Progress & progress, bool & kernel_switch_needed) Line 502 C++ blender.exe!ccl::Session::update_scene() Line 1029 C++ blender.exe!ccl::Session::run_cpu() Line 789 C++ blender.exe!ccl::Session::run() Line 864 C++ [Inline Frame] blender.exe!std::_Func_class<void>::operator()() Line 951 C++ blender.exe!ccl::thread::run(void * arg) Line 53 C++ [External Code] ```
This issue was referenced by 5c01ecd2bf
This issue was referenced by 5c01ecd2bf5d0dc0d42f90aba2a3d9f948d16bb8
Brecht Van Lommel self-assigned this 2020-11-12 20:23:49 +01:00
Reference: blender/blender#82516
