Prototype for instancing in node tree #82534
5 Participants
Reference: blender/blender#82534
Should be able to validate the design so the instancing system can work:
912b38001f
b081108819
5877e34eb4
Added subscribers: @JacquesLucke, @dfelinto
Added subscriber: @KenzieMac130
Added subscriber: @MiroHorvath
I made some progress on this. The code is currently in the
temp-modifiers-instancing
branch. It's still fairly limited, but it's getting there. :)One issue is that this only works when the modifier is on a point cloud object for now. That is because to make it work, I had to change the way modifiers are evaluated a bit. That is obviously much easier to do for point cloud objects, because there is nothing that I can break. Making it work when the modifier is on a mesh object is a bit more involved, but should still be doable. I'll look into that a bit later.
2020-11-10 16-34-37.mp4
Will the instances be allowed to be converted to geometry inside the node tree for further editing?
@astrand130 it is a bit early for this question. The prototype is intended to understand what can and can't be done given the requirements above (fast, memory efficient, can be implemented in a short time). This is enough for the use case that the project will support first. Anything beyond that falls outside the scope of the feature at this stage. It can be contemplated, but it won't be used to drive the decisions.
For completion sake, we also talked about what happens to the instances when you plug a subsurf modifier after the Nodes modifier. Or a boolean modifier. Ideally it should all be supported, but it is not a hard requirement for the initial scenarios.
On an related note, to be involved with the project It is easier to contact any team member on blender.chat to see where to help. This is not one of the nodes we would leave to contributors. But there are other parts that you can contribute to.
Added subscriber: @randum
Instances can be joined but boolean node seems does not work. I guess it should?
{F9398028, size=full}
@randum instancing happens outside the modifier tree. So boolean is not operating in the final evaluated mesh. Once this is committed to master (soon) this information will be present in the user manual entry for the point instance node. Meanwhile you can read about it here .
