Sample Texture Node for trees and flowers scattering #82584
9 Participants
Reference: blender/blender#82584
This node is for the trees and flowers scattering workflow.
{F9603276 size=full}
Added subscriber: @dfelinto
Added subscriber: @KenzieMac130
It seems like this is just pretty close to a duplicate of the image texture node based on the mockup. Why can't there just be a set float or set vector attribute node that accepts blender's existing texture nodes as well as any surface varying math node setups?
There is no image texture node at the moment. The design considered using an "image-base" pipeline, but for now it is focusing on an attribute pipeline. That means the texture doesn't exist on its own, but only in relation to a UV Map and the attribute the user intends to map it to.
I'm trying to figure out the issue here... I might be not understanding. It seems like the system doesn't handle surface varying attributes at the geometry node level. So user defined math that runs some sort of calculation per vertex/face would need to be piped through a "texture" (which based ony understanding of the design is basically going to be reusing the goodies of the material graph).
So if I wanted to say make an attribute or mask of a surfaces pointiness multiplied by a dot product vector and a grunge texture map I would need to create a texture graph that does such a thing and feed it into this node correct?
Or is this going to be a transition node for while blender does not have the new texture node system to hook into the old one?
(Edit: I will try to contact people on blender chat. Just figured the task page was the best place to leave open questions about design.)
Sample Texture Nodeto Sample Texture Node for trees and flowers scatteringAdded subscriber: @JacquesLucke
Added subscriber: @valera-8
Would be really cool if we could tie this to the texture generated in the Material editor, can be done like so:
Shader Tree Name: "Some Material"
Unique Node Name: "Node Name"
It would use the coordinates in the material editor. Imagine previewing the texture live on the object and then right away using it to distribute objects or displace mesh, etc..
The WIP code for this is in
temp-geometry-nodes-sample-texture
. It can only sample textures based on the position currently. I'll not be able to finish uv support in this sprint. It also requires changes to the distribute node, because the uv maps (and possibly all other attributes as well) have to be added to the output points.Added subscriber: @victorlouis
This issue was referenced by
425e706921
Added subscriber: @SimonThommes
@JacquesLucke for the records, remember to add a screenshot of the final node here. It helps to speed up testing.
If I remember correctly this is fully working. But I will let @SimonThommes to have a final say on it.
By the way, feedback by Andy: To add "Generated" mapping, besides UV, for when objects don't have UV mapping.
Also, there is the pending issue of the texture panel. IIRC the design is to follow the "Displace Modifier" design. If this won't be part of this task could you please create a new task in the product backlog so we don't forget that?
@dfelinto @JacquesLucke Yes, this task is done, I would say. But we should create new tasks for:
New
+ having a button to jump to said texture in the properties panel like in a displacement modifierAdded subscriber: @Rawalanche
What is the point of having such node when it can read only the old, Blender Internal style textures, and not Shader Editor texture node networks? This is the exact same issue as the one that severely limits the usefulness of the displace modifier. If your use case is truly scattering, as you say, then it makes really no sense for users to not have any ability to utilize the texture nodes.
My point is that the order seems to be all wrong. Ability to utilize node based texture networks in both Geometry Nodes and modifiers, such as Displacement Modifier would have much, much bigger impact on the overall capability of procedural modeling in Blender (think creating procedural rocks, cliffs, landscapes), than the geometry nodes with the support of old, gimped Blender Internal texture system will ever have.
@SimonThommes sounds good to me. I assume we could have a node that creates a new attribute that contains the generated coordinates? It's also possible to do this in the Sample Texture node of course. This question can also be answered in the new task.
Added subscribers: @HooglyBoogly, @lichtwerk
Just noting that in D9813: Sculpt / Paint: show "Show Texture in texture tab" button @HooglyBoogly raised the point to have some utility function that will determine the "right" Properties Editor to display this in:
I could have a look again and do it for this node as well?
@lichtwerk If you want to look into that, please go ahead. I don't consider this to be part of this task anymore.
@SimonThommes Can you create the tasks you mentioned?
