New Keyframe Smoothing Algorithm #82590
2 Participants
Reference: blender/blender#82590
Issue
The current keyframe smoothing algorithm has a fatal flaw in that it doesn't respect the keyframes x position. It works based on the index instead.
This means, that the smoothing only works correctly on evenly spaced keyframes.
Here's two pictures showing the difference.
Proposed Solution
Currently the algorithm used is called weighted moving-means. It can probably be patched to respect the x-position of the keyframe instead of the index.
However I think a low pass filter, where a float property controls the cutoff threshold would be more useful. This would make it so you could only remove high frequency detail if you wish.
In order to respect different use cases, those two could be chosen by an enum property in the redo panel.
Added subscriber: @ChrisLend
I tweaked the weighted moving means algorithm to respect x-position D9477
However I still think the smoothing algorithm could be better
Added subscriber: @BClark
A low pass "butterworth filter" would be great addition both as a destructive and a non-destructive (filter) for curves to help would be great
I'll close this down.
Butterworth is in progress and gaussian smooth that doesn't have the described issue is merged
