Applying scale doesn't matter on a 3D curve #82706
Reference: blender/blender#82706
Operating system: Windows 10
Graphics card: 1080ti
Broken: 2.90.1
Worked: -
After flipping an imported SVG to 3D and adding a bevel on it, the bevel's visual size and depth number stays the same after applying scale.
Result:
Nothing happens, except for the transform window switching scale to 1.0
Expected:
Either the bevel should visually change size or the depth number should change its value.
Added subscriber: @RobertS
Added subscriber: @iss
Can't find reason why this happens but it looks it should not happen.
Added subscriber: @EAW
I noticed that the mean radius changes from 1.0 to 20.0 after applying the scale. To see this, you have to jump into edit mode before and after applying the scale. I just tested and this behavior goes back to at least 2.79b. To get the 'expected' result of a much smaller bevel, I had to manually adjust the mean radius in edit mode to be 1.0. If a curve is scaled in edit mode, this issue does not occur.
Further research shows shows that this behavior is intentional. See the explanations in #35305 (Apply Scale in curves don't work as is supposed to.), #34533 (bezier curve extrusion seems to be wrong after applying scale.), and #72149 (curve geometry extrude does not respect scale.).
@EAW Thanks, I have noticed that it changes the radius, but I didn't know this affects bevel. I think this is best described by #34533 so I will merge this.
Closed as duplicate of #34533
