Crash rendering particle animation with particle caches [disk cache works though] #82769
Closed
opened 2020-11-17 01:51:59 +01:00 by Bernhard Engstler · 25 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-14 03:36, hash: 9b54c81414
Worked: 2.90.1
Worked: 2.83.9
Caused by 263148dbac
Rendering an animation with two particle systems using Cycles or Eevee results in a crash
Stack trace:
blender.exe         :0x00007FF7C378C910  ptcache_particle_read
blender.exe         :0x00007FF7C378D0A0  ptcache_read
blender.exe         :0x00007FF7C3789BC0  BKE_ptcache_read
blender.exe         :0x00007FF7C3783780  system_step
blender.exe         :0x00007FF7C377D870  particle_system_update
blender.exe         :0x00007FF7C39FED20  deformVerts
blender.exe         :0x00007FF7C37B1F70  mesh_calc_modifiers
blender.exe         :0x00007FF7C37B1CB0  mesh_build_data
blender.exe         :0x00007FF7C37B1AF0  makeDerivedMesh
blender.exe         :0x00007FF7C37DB030  BKE_object_handle_data_update
blender.exe         :0x00007FF7C37DAD60  BKE_object_eval_uber_data
blender.exe         :0x00007FF7C740BE30  std::_Func_impl_no_alloc<std::_Binder<std::_Unforced,void (__cdecl&)(Depsgraph * __ptr64,Main * __p
blender.exe         :0x00007FF7C740A210  blender::deg::`anonymous namespace'::evaluate_node
blender.exe         :0x00007FF7C740A1C0  blender::deg::`anonymous namespace'::deg_task_run_func
tbb.dll             :0x00007FFEDBA351D0  tbb::interface7::internal::isolate_within_arena
blender.exe         :0x00007FF7C748E410  tbb::internal::function_task<Task>::execute
tbb.dll             :0x00007FFEDBA437A0  tbb::recursive_mutex::scoped_lock::internal_try_acquire
blender.exe         :0x00007FF7C3A565E0  tbb::internal::task_group_base::wait
blender.exe         :0x00007FF7C7409D50  blender::deg::deg_evaluate_on_refresh
blender.exe         :0x00007FF7C36DAFF0  scene_graph_update_tagged
blender.exe         :0x00007FF7C3862730  wm_event_do_notifiers
blender.exe         :0x00007FF7C384D2F0  WM_main
blender.exe         :0x00007FF7C35596E0  main
blender.exe         :0x00007FF7C79B3888  __scrt_common_main_seh
KERNEL32.DLL        :0x00007FFEEB787020  BaseThreadInitThunk
ntdll.dll           :0x00007FFEED51CEA0  RtlUserThreadSta
{F9306181}
  • Open the project file attached below
  • Render the animation
{F9317435}
Workaround
  • enable Render > Lock Interface or
  • bake to disk cache
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71 **Blender Version** Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-14 03:36, hash: `9b54c81414` Worked: 2.90.1 Worked: 2.83.9 Caused by 263148dbac **Short description of error** Rendering an animation with two particle systems using Cycles or Eevee results in a crash ```lines Stack trace: blender.exe :0x00007FF7C378C910 ptcache_particle_read blender.exe :0x00007FF7C378D0A0 ptcache_read blender.exe :0x00007FF7C3789BC0 BKE_ptcache_read blender.exe :0x00007FF7C3783780 system_step blender.exe :0x00007FF7C377D870 particle_system_update blender.exe :0x00007FF7C39FED20 deformVerts blender.exe :0x00007FF7C37B1F70 mesh_calc_modifiers blender.exe :0x00007FF7C37B1CB0 mesh_build_data blender.exe :0x00007FF7C37B1AF0 makeDerivedMesh blender.exe :0x00007FF7C37DB030 BKE_object_handle_data_update blender.exe :0x00007FF7C37DAD60 BKE_object_eval_uber_data blender.exe :0x00007FF7C740BE30 std::_Func_impl_no_alloc<std::_Binder<std::_Unforced,void (__cdecl&)(Depsgraph * __ptr64,Main * __p blender.exe :0x00007FF7C740A210 blender::deg::`anonymous namespace'::evaluate_node blender.exe :0x00007FF7C740A1C0 blender::deg::`anonymous namespace'::deg_task_run_func tbb.dll :0x00007FFEDBA351D0 tbb::interface7::internal::isolate_within_arena blender.exe :0x00007FF7C748E410 tbb::internal::function_task<Task>::execute tbb.dll :0x00007FFEDBA437A0 tbb::recursive_mutex::scoped_lock::internal_try_acquire tbb.dll :0x00007FFEDBA437A0 tbb::recursive_mutex::scoped_lock::internal_try_acquire blender.exe :0x00007FF7C3A565E0 tbb::internal::task_group_base::wait blender.exe :0x00007FF7C7409D50 blender::deg::deg_evaluate_on_refresh blender.exe :0x00007FF7C36DAFF0 scene_graph_update_tagged blender.exe :0x00007FF7C3862730 wm_event_do_notifiers blender.exe :0x00007FF7C384D2F0 WM_main blender.exe :0x00007FF7C35596E0 main blender.exe :0x00007FF7C79B3888 __scrt_common_main_seh KERNEL32.DLL :0x00007FFEEB787020 BaseThreadInitThunk ntdll.dll :0x00007FFEED51CEA0 RtlUserThreadSta ``` {F9306181} **Exact steps for others to reproduce the error** - Open the project file attached below - Render the animation {F9317435} **Workaround** - enable `Render` > `Lock Interface` or - bake to disk cache
Added subscriber: @B_Engstler
Added subscriber: @rjg
According to the crash log it happens when accessing the particle cache. The CUDA/OptiX denoiser problem seems like a separate issue. Please try to create a minimal version of the project that still results in a crash and upload it here.
According to the crash log it happens when accessing the particle cache. The CUDA/OptiX denoiser problem seems like a separate issue. Please try to create a *minimal* version of the project that still results in a crash and upload it here.
The hint with the particles helped a lot to reduce the scene to a minimum and get a closer idea of what is causing the trouble. It only crashes if disk cache is unchecked, but if I bake to disk cache it does not crash anymore. Anyway, here's the file:
ani_SH_180_v004_bE_debug.zip
The hint with the particles helped a lot to reduce the scene to a minimum and get a closer idea of what is causing the trouble. It only crashes if disk cache is unchecked, but if I bake to disk cache it does not crash anymore. Anyway, here's the file: [ani_SH_180_v004_bE_debug.zip](https://archive.blender.org/developer/F9317435/ani_SH_180_v004_bE_debug.zip)
Added subscriber: @Andreas80
I can reproduce the crash regardless of the denoiser in 2.91+, 2.83.9 works fine. This seems to be an issue with the particle system cache or how it's processed. Using Delete All Bakes and then Bake All Dynamics on both particle systems doesn't make a difference. However, Delete All Bakes, enabling Disk Cache and then Bake All Dynamics appears to avoid the crash.
ptcache_particle_read(int index, void * psys_v, void * * data, float cfra, const float * old_data) Lines 345	C
ptcache_read(PTCacheID * pid, int cfra) Lines 2183	C
BKE_ptcache_read(PTCacheID * pid, float cfra, bool no_extrapolate_old) Lines 2313	C
system_step(ParticleSimulationData * sim, float cfra, const bool use_render_params) Lines 4516	C
particle_system_update(Depsgraph * depsgraph, Scene * scene, Object * ob, ParticleSystem * psys, const bool use_render_params) Lines 4934	C
deformVerts(ModifierData * md, const ModifierEvalContext * ctx, Mesh * mesh, float- [x] * vertexCos, int numVerts) Lines 229	C
mesh_calc_modifiers(Depsgraph * depsgraph, Scene * scene, Object * ob, int useDeform, const bool need_mapping, const CustomData_MeshMasks * dataMask, const int index, const bool use_cache, const bool allow_shared_mesh, Mesh * * r_deform, Mesh * * r_final) Lines 991	C
mesh_build_data(Depsgraph * depsgraph, Scene * scene, Object * ob, const CustomData_MeshMasks * dataMask, const bool need_mapping) Lines 1806	C
makeDerivedMesh(Depsgraph * depsgraph, Scene * scene, Object * ob, BMEditMesh * em, const CustomData_MeshMasks * dataMask) Lines 1927	C
BKE_object_handle_data_update(Depsgraph * depsgraph, Scene * scene, Object * ob) Lines 194	C
BKE_object_eval_uber_data(Depsgraph * depsgraph, Scene * scene, Object * ob) Lines 385	C
 	[External Code]
blender::deg::`anonymous namespace'::deg_task_run_func(TaskPool * pool, void * taskdata) Lines 127	C++
 	[External Code]
tbb::interface7::internal::isolate_impl<void,void <Lambdafunktion>(void) const>(const Task::()::__l2::void <Lambdafunktion>(void) & f) Lines 160	C++
Task::operator()() Lines 122	C++
tbb::internal::function_task<Task>::execute() Lines 1049	C++
 	[External Code]
tbb::internal::task_group_base::wait() Lines 168	C++
blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph * graph) Lines 398	C++
scene_graph_update_tagged(Depsgraph * depsgraph, Main * bmain, bool only_if_tagged) Lines 2592	C
wm_event_do_depsgraph(bContext * C, bool is_after_open_file) Lines 356	C
wm_event_do_refresh_wm_and_depsgraph(bContext * C) Lines 384	C
wm_event_do_notifiers(bContext * C) Lines 562	C
WM_main(bContext * C) Lines 641	C
main(int argc, const unsigned char * * UNUSED_argv_c) Lines 527	C
 	[External Code]
I can reproduce the crash regardless of the denoiser in 2.91+, 2.83.9 works fine. This seems to be an issue with the particle system cache or how it's processed. Using *Delete All Bakes* and then *Bake All Dynamics* on both particle systems doesn't make a difference. However, *Delete All Bakes*, enabling *Disk Cache* and then *Bake All Dynamics* appears to avoid the crash. ```lines ptcache_particle_read(int index, void * psys_v, void * * data, float cfra, const float * old_data) Lines 345 C ptcache_read(PTCacheID * pid, int cfra) Lines 2183 C BKE_ptcache_read(PTCacheID * pid, float cfra, bool no_extrapolate_old) Lines 2313 C system_step(ParticleSimulationData * sim, float cfra, const bool use_render_params) Lines 4516 C particle_system_update(Depsgraph * depsgraph, Scene * scene, Object * ob, ParticleSystem * psys, const bool use_render_params) Lines 4934 C deformVerts(ModifierData * md, const ModifierEvalContext * ctx, Mesh * mesh, float- [x] * vertexCos, int numVerts) Lines 229 C mesh_calc_modifiers(Depsgraph * depsgraph, Scene * scene, Object * ob, int useDeform, const bool need_mapping, const CustomData_MeshMasks * dataMask, const int index, const bool use_cache, const bool allow_shared_mesh, Mesh * * r_deform, Mesh * * r_final) Lines 991 C mesh_build_data(Depsgraph * depsgraph, Scene * scene, Object * ob, const CustomData_MeshMasks * dataMask, const bool need_mapping) Lines 1806 C makeDerivedMesh(Depsgraph * depsgraph, Scene * scene, Object * ob, BMEditMesh * em, const CustomData_MeshMasks * dataMask) Lines 1927 C BKE_object_handle_data_update(Depsgraph * depsgraph, Scene * scene, Object * ob) Lines 194 C BKE_object_eval_uber_data(Depsgraph * depsgraph, Scene * scene, Object * ob) Lines 385 C [External Code] blender::deg::`anonymous namespace'::deg_task_run_func(TaskPool * pool, void * taskdata) Lines 127 C++ [External Code] tbb::interface7::internal::isolate_impl<void,void <Lambdafunktion>(void) const>(const Task::()::__l2::void <Lambdafunktion>(void) & f) Lines 160 C++ Task::operator()() Lines 122 C++ tbb::internal::function_task<Task>::execute() Lines 1049 C++ [External Code] tbb::internal::task_group_base::wait() Lines 168 C++ blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph * graph) Lines 398 C++ scene_graph_update_tagged(Depsgraph * depsgraph, Main * bmain, bool only_if_tagged) Lines 2592 C wm_event_do_depsgraph(bContext * C, bool is_after_open_file) Lines 356 C wm_event_do_refresh_wm_and_depsgraph(bContext * C) Lines 384 C wm_event_do_notifiers(bContext * C) Lines 562 C WM_main(bContext * C) Lines 641 C main(int argc, const unsigned char * * UNUSED_argv_c) Lines 527 C [External Code] ```
@B_Engstler Do you know how you managed to create the file where the particle cache seemingly breaks 2.91 and 2.92?
Member
Added subscriber: @lichtwerk
Member
Member
Will check
Will check
Robert Guetzkow changed title from Crash rendering animation in Cycles - EXCEPTION_ACCESS_VIOLATION; Adress 0x00007FF7C378C987 to Crash rendering particle animation in Cycles 2020-11-19 11:59:54 +01:00
Member
Forgot that I need to fix my CUDA installation, thus cannot fully bisect, but it broke between 940b239ad4 (good) an e4932d1167 (bad)
I just recreated a very basic scene with only one emitter (default cube) and another subdivided and displaced cube as particle object. To me it seems that somehow it is related to change the emitter object on a mesh level and baking again, e.g. deleting a face, bake again, safe file, render. But I'm not 100% sure, this seems very erratic.
ParticleTest.blend
This basic scene crashes immediately upon opening and rendering (Ctrl F12).
I just recreated a very basic scene with only one emitter (default cube) and another subdivided and displaced cube as particle object. To me it seems that somehow it is related to change the emitter object on a mesh level and baking again, e.g. deleting a face, bake again, safe file, render. But I'm not 100% sure, this seems very erratic. [ParticleTest.blend](https://archive.blender.org/developer/F9324717/ParticleTest.blend) This basic scene crashes immediately upon opening and rendering (Ctrl F12).
Member
For me, ani_SH_180_v004_bE_debug seems to survive if I have Render > Lock Interface checked.
@B_Engstler : can you confirm?
For me, `ani_SH_180_v004_bE_debug` seems to survive if I have `Render` > `Lock Interface` checked. @B_Engstler : can you confirm?
Yes! It rendered a couple of times now without crashing and locked interface, unchecking it crashes during first render attempt. It also crashes with CPU rendering for me.
> In #82769#1057687, @lichtwerk wrote: > For me, `ani_SH_180_v004_bE_debug` seems to survive if I have `Render` > `Lock Interface` checked. > > @B_Engstler : can you confirm? Yes! It rendered a couple of times now without crashing and locked interface, unchecking it crashes during first render attempt. It also crashes with CPU rendering for me.
Member
For me, too [that means I can do the bisect though :)]
> It also crashes with CPU rendering for me. For me, too [that means I can do the bisect though :)]
Member
Philipp Oeser changed title from Crash rendering particle animation in Cycles to Crash rendering particle animation with particle caches [disk cache works though] 2020-11-19 14:20:49 +01:00
Member
Member
CC @JacquesLucke (feel free to set back to lower prio, just letting you know this is bisected and a regression in 2.91 from 2.90.1)
Jacques Lucke self-assigned this 2020-11-19 17:32:18 +01:00
Member
Not sure how 263148dbac caused this regression, but D9606 seems to fix the threading issue.
Not sure how 263148dbac caused this regression, but [D9606](https://archive.blender.org/developer/D9606) seems to fix the threading issue.
This issue was referenced by dca36a8ec9
This issue was referenced by dca36a8ec922bcce6bc4882cd6cba52792ed56ee
Member
This comment was removed by @rjg
*This comment was removed by @rjg*
I can confirm this fixes the problem. In my previous comment I didn't notice that this was not yet merged into master.
6 Participants
Reference: blender/blender#82769
