Bump map texture painting in 3d viewport applies gamma correction to 32-bit float noncolor image data. #82818
2 Participants
Reference: blender/blender#82818
Operating system: NA (Windows-10-10.0.18362-SP0 64 Bits, Darwin)
Graphics card: NA (GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35, AMD Radeon HD 6970M 4.1 ATI-1.68.25)
Broken: version: 2.90.1, 2.92.0 Alpha, branch: master, commit date: 2020-11-18 13:26, hash:
f132d74c7d
When texture painting a float non color image, the
3D viewport
uses a differentmix
algorithm than the one used on byte images in the 3D viewport, and floats and bytes in theImage Editor
.Exact steps for others to reproduce the error
Problem with texture painting bump maps. The image above shows two drawn curves. The left curve was drawn in the image editor, the right curve was drawn in the 3D viewport. Brush color is set to (r,g,b)=(0.6,0.6,0.6). The image texture used for the bump map was generated by the brush tool which creates a noncolor image set to 0.5. The problem occurs when specifying a 32-bit float for that image.
You can open the 2 following .blend files, and try painting a stroke in both the 3D viewport and the Image editor.
T82818_texturepaint_mix_byte.blend
T82818_texturepaint_mix_float.blend
system-info.txt
Added subscriber: @pcschubert
Added subscriber: @EAW
I can confirm, will check to see if this is a known issue.
Changed status from 'Confirmed' to: 'Needs Triage'
