FBX Import: Can't import FBX file. AttributeError:'NoneType' object has no attribute 'data' #82830
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#82830
Operating system: Windows-10-10.0.14393-SP0 64 Bits
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.15
Broken: version: 2.91.0 Beta, branch: master, commit date: 2020-11-17 22:01, hash:
blender/blender@e580c18853
Worked: 2.79
This is an issue that was closed prior due to unresponsive user that affected 2.82 to the beta version of 2.91.
I tested it on the stable release 2.90.1 as well.
An FBX I attempt to import into Blender fails to load in with the following.
if import_fbx.load(self, context, filepath=path, **keywords) == {'FINISHED'}:
(); del _
fbx_item[1] = blen_read_geom(fbx_tmpl, fbx_obj, settings)
blen_read_geom_layer_color(fbx_obj, mesh)
blen_data = color_lay.data
{F9320007}
{F9320013}
Here I've uploaded two files. The smallest one is a 2015 FBX.
The other one is 2018 FBX.
They both give the same error.
I open Blender, I select everything in viewport, delete, then I import FBX, and import one of the two appended files.
These are my import settings.
https://i.imgur.com/UqJ6Btq.png
Added subscriber: @GeekyGami
Adding details for context, might be useful.
So, I'm using SB3UGS to export FBX from a Unity game.
I'm specifically exporting a skinnedmeshrenderer with its morphs (Blendshapes)
I have an option I can check, for it to export "morph masks"
When that option is checked, and I import the resulting FBX (I.E. one of those two) is when the error occurs.
When it is unchecked, it imports fine.
So, I think this might have something to do with morph masks.
Added subscriber: @rjg
The source of the problem is Blender's limit of eight vertex color layers. The file contains more and the
*.fbx
importer doesn't keep track how many have been created before. If the limit is reachedmesh.vertex_colors.new(name=fbx_layer_name, do_init=False)
returnsNone
. The importer should handle this case properly, hence I'm marking this as confirmed.In a cursory check I've noticed that other importers, e.g. PLY, coat3D or X3D don't seem to handle this case properly either. A similar check would also be necessary for UV layers as these have a hard limit as well.
Added subscriber: @Limarest
Tested files with BetterFBX addon - imported correctly and even had the shape keys
@Limarest When including a check for the return value, it imports the file fine as well. Neither the official FBX importer nor a third-party add-on can change the limits though, so only eight vertex color layers will be loaded.
This issue was referenced by
a0e8b8b787
