GreasePencil: Crash when changing to Vertex Color mode in Draw mode
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-18 22:29, hash: rB9d6d5b9bebd1
Worked: 2.90.1
Crash when changing to Vertex Color mode in Draw mode.
Occurs in Blender 2.92.0 Alpha and 2.91.0 Beta.
OS Conditon: WIN 10 |Blender: 2.92.0 Alpha
  • Default scene.
  • Create a Grease Pencil Blank ,go into Draw mode and change to the Vertex Color mode, then make a stroke
Below is a simple file in which the default cube is deleted and having a blank Grease Pencil object in Draw mode:
Crash should be able to reproduced by turning on the Vertex Color mode.
I cannot reproduce it using last source code.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.EditedThu, Nov 19, 9:47 AM
Can reproduce with rB8ec6b34b8eb2: VSE: Move split operator logic to module code.
You have to make a stroke after changing to Vertex Color mode
but->tip is NULL
1  __strchr_avx2                                             0x7ffff7945fcc
2  ui_but_tip_len_only_first_line interface_query.c    466   0x466a3c6
3  ui_apply_but_undo              interface_handlers.c 835   0x4629d01
4  button_activate_exit           interface_handlers.c 8214  0x463e9c2
5  ui_handle_button_event         interface_handlers.c 8951  0x464052a
6  ui_region_handler              interface_handlers.c 10681 0x464470d
7  wm_handler_ui_call             wm_event_system.c    639   0x386dec5
8  wm_handlers_do_intern          wm_event_system.c    2764  0x38733bc
9  wm_handlers_do                 wm_event_system.c    2872  0x38737b4
10 wm_event_do_handlers           wm_event_system.c    3368  0x3874dca
11 WM_main                        wm.c                 635   0x3869039
12 main                           creator.c            522   0x32f3842
Will bisect.
@Philipp Oeser (lichtwerk) I see now. Is this related to GPencil? Looking at the callstack I see it looks related to UI code.
This should do the trick
1
2
3diff --git a/source/blender/editors/interface/interface_query.c b/source/blender/editors/interface/interface_query.c
4index d0075ba8617..7be7ca7cad0 100644
5--- a/source/blender/editors/interface/interface_query.c
6+++ b/source/blender/editors/interface/interface_query.c
7@@ -463,6 +463,9 @@ size_t ui_but_drawstr_len_without_sep_char(const uiBut *but)
8
9 size_t ui_but_tip_len_only_first_line(const uiBut *but)
10 {
11+ if (but->tip == NULL) {
12+ return 0;
13+ }
14 const char *str_sep = strchr(but->tip, '\n');
15 if (str_sep != NULL) {
16 return (str_sep - but->tip);
1
2
8
10 {
12+ return 0;
13+ }
Small note, @炎臻 (PrettyFireNOI7) nice presentation of the bug report. Usually it is not encouraged to deviate from the template, but I actually like what you did here
Thank you.
