GPU volume glitch with an emissive plane and camera/view inside volume object #82902
5 Participants
Reference: blender/blender#82902
Graphics card: GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash:
211b6c29f7
As you open the blend file and go into rendered view the back plane that has emissive properites will clip trough rest of the mesh. It's nothing major luckily, just a visual bug
Station_39.blend
Open the attached blend file, DO NOT move the world view. Go in to rendered view on the right window.
The
Material.013
material onNeon_kyltit
in combination withMaterial.003
onTausta_blue
seem to cause the glitches (for me)Glitch looks like this btw and only appear on GPU.:
This is on CPU
Material.013
is not even assigned to any faces.If any of the two get removed, all is good again.
Checked a bit more and here is a simplified file:
Volume_emission_glitch.blend
Looks like this then:
Added subscriber: @Nuudom
Not that in depth with the inner workings of blender, but came accross this visual bug
Added subscriber: @Alaska
The issue seems to be caused by the emission shader plugged into the volume output on the plane that shows the visual glitches. Unplugging the emission shader seems to fix this issue.
As for why the emission shader is causing issues, it seems to have something to do with the fact the plane is a backface on both sides, causing the "outside" to be the volume in which the volume shader takes effect? However, that doesn't explain why it only effects a certain area of the scene.
Added subscriber: @mano-wii
I'm not sure I can identify the problem:
Added subscriber: @lichtwerk
The
Material.013
onTausta_blue
seem to cause the glitches (for me)They look like this btw and only appear on GPU.:
This is on CPU
Material.013
Will confirm for now (even though this looks like a real corner-case?)
A visual bug with an emissive plane and rendered viewto GPU volume glitch with an emissive plane and camera/view inside volume objectI have absolutely no idea how to reproduce this. I played around a bit and have personally been unable to reproduce this. Maybe @Nuudom can shed some light on this?
I actually have no idea how I managed that 😅 i didn't know why the plane was connected to an volume output to begin with to be honest.
All I can guess at with my tiny knowleage is that I may have made too many clicks and key shortcuts at the same time and it just bugged out.
Maybe someone familiar with code could view the project data if that file has any.
Added subscriber: @brecht
Blender 3.0 is giving consistent results for CPU and GPU here. Beyond that the mesh does not appear to be closed, which is required for volume rendering to work correctly.
